hardware|hercules VIRTUAL DJ SOFTWARE - Hardware Manuals - Hercules - Instinct P8 - Pads
Hardware Manuals
PADS
LOOP MODE
Hold MODE button [15] down and then press Pad 1 to set Pads to Loop Roll mode.
Press and hold a Pad down to apply a Loop of a different size in beats. When Pad is released, the track will resume playing from the position it would have been if the Loop was never applied.
KEY
ACTION
SHIFT (SECONDARY) ACTION
P1 PAD1
Applies a Loop Roll of 1/8 beat
Loop In : When not in loop, sets current position as the beginning of the Loop. If in loop, jumps to the beginning of the loop
P2 PAD2
Applies a Loop Roll of 1/4 beat
Loop Out: When not in loop, sets deck in loop, starting from the last Loop In point. When in Loop, exits the Loop
P3 PAD3
Applies a Loop Roll of 1/2 beat
Reloop : When not in loop, jumps to the beginning of the previously triggered loop and sets deck in loop. When in loop, jumps to its beginning
P4 PAD4
Applies a Loop Roll of 1 beat
Records deck to a new Sample
FX MODE
Hold MODE button[15] down and then press Pad 2to set Pads to Effects mode.
P1 PAD1
Enables/disables the selected Effect of FX Slot 1
Selects the next available Effect for FX Slot 1
P2 PAD2
Enables/disables the selected Effect of FX Slot 2
Selects the next available Effect for FX Slot 2
P3 PAD3
Enables/disables the selected Effect of FX Slot 3
Selects the next available Effect for FX Slot 3
P4 PAD4
Enables/disables the FX Parameter mode. When enabled (LED on), use the LOOP ENC to adjust the 1st Parameter of all 3 FX Slots. Hold SHIFT down and then use the same LOOP ENC to adjust the 2nd Parameter of all 3 FX Slots
SAMPLE MODE
Hold MODE button [15] down and then press Pad 3 to set Pads to Sampler mode.
While Pads are in Sampler mode, hold the MODE button [15] down and use the LOOP ENC to adjust the Master Volume of the Sampler.
KEY
ACTION
P1 PAD1
Triggers Sample 1/5* from the selected Sampler Bank
Selects and loads the previous available Sampler Bank
P2 PAD2
Triggers Sample 2/6* from the selected Sampler Bank
Selects and loads the next available Sampler Bank
P3 PAD3
Triggers Sample 3/7* from the selected Sampler Bank
Sets Sampler Pads to On/Off trigger mode
P4 PAD4
Triggers Sample 4/8* from the selected Sampler Bank
Sets Sampler Pads to Hold trigger mode (play while pressed)
*Note: If the selected Sampler Bank has less than 5 samples, both sides of the Pads will trigger the same samples. If the selected Sampler Bank has more than 4 samples, the left side Pads will trigger Samples 1 to 4 and the right side Pads will trigger Samples 5 to 8.
CUE MODE
Hold MODE button [15] down and then press Pad 4 to set Pads to Hotcue mode.
KEY
ACTION
P1 PAD1
Sets current track's position as Hotcue 1 if not set or jumps to it's stored position if set.
Deletes Hotcue 1
P2 PAD2
Sets current track's position as Hotcue 2 if not set or jumps to it's stored position if set.
Deletes Hotcue 2
P3 PAD3
Sets current track's position as Hotcue 3 if not set or jumps to it's stored position if set.
Deletes Hotcue 3
P4 PAD4
Sets current track's position as Hotcue 4 if not set or jumps to it's stored position if set.
Deletes Hotcue 4
For further Technical features and specifications, visit
Hercules DJ Control Instinct P8
Product's Page
Hardware Integration Department
2018 - ATOMIX PRODUCTIONS
Reproduction of this manual in full or in part without written permission from Atomix Productions is prohibited.
