Firmware Version v.1.02 for the TotalControl was released on 08.12.2008. New Firmware Update Instructions were also published to the site. All TotalControl owners can download this update for free at www.numark.com/totalcontrol
This update resolves issues with Usb connectivity some users have experienced and boosts general performance.
Best Regards
__________________
Simon Bangs
Computer DJ/VJ product Specialist.
Numark Alesis Europe
Best Regards
__________________
Simon Bangs
Posted Tue 12 Aug 08 @ 2:39 pm
finally got it to work
instructions on how to do it are here
http://www.numark.com/stuff/contentmgr/files/20/374d00b4f68ea82b710d8a9cc9bb01f8/file/totalcontrol_firmware_update_instructions.pdf
Disconnect any usb interface before to start the update
1) Download the .zip file containing the latest firmware from http://www.numark.com/stuff/contentmgr/files/20/51bb879b572f44112f0108a21f1445ec/file/totalcontrol_v1_02.zip and extract its contents.
2) Make sure the Total Control is disconnected from your computer.
3) Hold down the PLAY/STUTTER button of the left deck and the CUE button of the right deck simultaneously
connecting the Total Control to your computer. The LEDs next to the mid-range EQ knobs will light up.
Note: If the LEDs next to the treble and mid-range EQ knobs light up, this means there is no firmware
the Total Control. Proceed to Step 4.
4) Press the two mid-range EQ knobs simultaneously. The LEDs should now be unlit, and after a few seconds, ON/OFF button on both decks should be lit.
5) Open sysexbox.exe -> http://miostools.midibox.org/sysexbox_18f_v1_1c.zip
select "Usb Speakers" in "midi IN & OUT port"
"Open Sysex file"
"Send Sysex"
The buttons in the EFFECT sections and SAMPLE sections will flicker as the file uploads.
When it is finished, the PLAY buttons in the SAMPLE and the LEDs next to the mid-range EQ knobs will light up.
6) Press the two mid-range EQ knobs simultaneously. All buttons and LEDs should now be unlit.
7) Disconnect and reconnect the Total Control to your computer to begin using it with the new firmware.
cheers,
matt
Edit by Cioce
Setup operation clarified
"Open Sysex file"
"Send Sysex"
cheers,
matt
Edit by Cioce
Posted Thu 14 Aug 08 @ 5:54 am
Cheers for sharing , i am happy to say this update also reduces the latency of the controller drastically!
Posted Thu 14 Aug 08 @ 2:27 pm
especially the channel faders
they are a LOT more responsive now
Posted Fri 15 Aug 08 @ 6:03 am
HELP!!!
I've ran through this perfectly twice now and my VDJ has stopped working with total control.
Please can someone post the old firmware up asap!
If you haven't done this update yet I think you can help me out by loading the sysexbox and doing a sysex dump of the old version.
If someone could do this and post a link it would be much appreciated.
please help, this sucks bad!
Posted Sat 23 Aug 08 @ 6:38 am
I confirm, the channel faders delay latency (after 1 year of waiting) is now fixed!!!
This info is now into the Common Device Drivers WIKI http://www.virtualdj.com/wiki/index.php/Common_Device_Drivers
@ dhe8dave
Try to reload the firmware and connect only the total control, during my update with M-audio Fast Track PRO audio card connected the firmware procedure was locked.
Posted Sat 23 Aug 08 @ 8:44 am
hey cioce,
thanx a lot for making everything more clear & simple
it took me a while to figure things out . . .
so, i was kind of tired to detailize everything ;-)
cheers,
matt
cheers,
matt
Posted Tue 26 Aug 08 @ 7:25 am
Posted Fri 29 Aug 08 @ 4:13 am
I really need help.....when i open the sysexbox and try to select usb speakers in my midi in and out....it doesnt work....the numark total control isnt there. ....why please help me?
djlahawk@yahoo.com
If you want you can call me at 773-457-0797 24 hr/7 days a week...Ive only had this total control for about 2 weeks
djlahawk@yahoo.com
Posted Sun 31 Aug 08 @ 10:11 am
it's not always called usb speakers
in my case, as i remember, it was usb soundcard or something
do not connect(usb) anything else but the total control
and it should be the only "usb" device showing up in the drop down list
hope this helped
matt
hope this helped
matt
Posted Sun 31 Aug 08 @ 2:37 pm
I start to have some problem with this new firmware, sometimes the unit it's not recognize by Virtual DJ.
If I do the manual unistaller procedure of the USB Speaker from my windows XP SP3, I reconnect the unit, windows start to reinstall and after this it work but I don't want to do this operation any time.
Simon...
Simon...
Posted Mon 01 Sep 08 @ 3:11 am
hi it took me 2 reinstalations but it work wonderful, the total control is great. I have the behringer bcd3000 but there was no way to confi it. thanks loads.
Posted Mon 01 Sep 08 @ 3:17 am
cioce,
sorry to hear that
haven't ran into any problems so far
hope it stays like that
anyone else experiencing problems ?
sorry to hear that
Posted Tue 02 Sep 08 @ 2:15 am
Hey Cioce,
Had the same problem since I upgraded firmware - but I only have to quit VDJ, then disconnect / reconnect my DJIO from USB.
When I launch VDJ again, everything works fine.
If you have a DJIO maybe you should try...
I don't really understand the link between NTC firmware upgrade and DJIO, but I am sure I did not have the problem before upgrading the NTC...
Posted Tue 02 Sep 08 @ 6:22 am
LeonZeBourdon wrote :
Hey Cioce,
Hi , there is no link with the Total Control and the DJio.
I would recommend ensuring you have the latest version of the DJio driver for your computer and ensuring you have no conflicting usb devices.
http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
If you still have issues please contact Numark support directly in your area.
Posted Wed 03 Sep 08 @ 2:44 pm
Simon...
Simon...
Hi Cioce i think this is an issue with your computer i will contact you via Email.
Posted Wed 03 Sep 08 @ 2:46 pm
i am having trouble nothing is installing corretly, i chose numark tc instead of usb and when i try to find data to send there is none is there anyway i can remedy this?
any help is appreciated
thanks
thanks
Posted Wed 01 Oct 08 @ 8:00 am
@ skyfxl
I coming back to old 1.1 Firmware and I will see if whit same M-Audio Fast track PRO Audio Card I have same problem, if no it's logical, the problem is new firmware.
In any case thanks a lot for your support.
Posted Wed 01 Oct 08 @ 8:44 am
From Numark forum:
Simon Bangs wrote :
This firmware is now available via technical support only.
Please contact support@numark.com if you need help.
Kind Regards
__________________
Simon Bangs
Kind Regards
__________________
Simon Bangs
Posted Fri 10 Oct 08 @ 3:59 am
Does anyone have the earlier firmware versions available? I'm having trouble keeping my total control 'active.' Everytime I switch it to active and then go into preferences, it unchecks itself. This happens in Traktor 3.2 and LE included with the total control.
Anyone know the issue?
Posted Mon 03 Nov 08 @ 3:33 am
