Forum: Old versions
Topic: Maya44 USB or u46dj - Page: 2
Did u mean this one?
http://www.numark.com/battlepakv4
"A READY-TO-GO DJ SCRATCH SYSTEM THAT PUTS YOU IN CONTROL
No need to look any further when you can get started instantly with the Numark Battle Pack DJ System. This system includes:
1 Numark DM950 mixer
2 Numark TT1625 turntables with cartridges and a pair of slipmats
1 pair of Numark HF125 headphones, and all connecting cables.
The Numark DM950 is a compact, rugged mixer packed with essential features. Includes a replaceable crossfader, 2-band EQ per channel, durable steel construction, a comfortable sloped front panel, 2 phono- and 2 line-level RCA inputs, and a 1/4" mic input
The Numark TT1625 is a direct-drive turntable featuring 10% pitch adjustment, 33 and 45rpm speeds, an aluminum platter, S-shaped tone arm, and dual start/stop controls
Numark HF125 headphones feature flexible, 7-position, independently adjustable padded ear cups; large 40mm mylar speaker drivers; 6' tangle-resistant cord; and padded headband"
Quote from the numark site
Hmmm.. As long it is direct drive n u not gonna use it professional n u getting started, in my view it is ok with those..;) But i don't recommend it for pro use.
cool guys, i will go with TT200. tnx, now what do about this Numark CC1 DJ Mix Cartridge & Stylus
Endorsed by the Scratch Perverts
Plug in silver design
Ideal for general use
18 grams
u have to but for TT200. they dont have the catridge.
You might want to check out the direct drive battle pack spinna points out above. Otherwise those cartridges you mention will suit you just fine.
awsome, thank for your help
does direct drive Numark Battle pack work with Maya 44 and timecoded virtual vinyl? ;)
Yes, it should werk. For timecoded purpose it is important to have the correct SC as in this case maya which have 2 stereo in n 2 stereo out werk as the interface between ur mixer n ur lappy. The TT will be connected via ur mixer.. But just on the side note as ur mixer is not a midi mixer, it will not act as a controller example the crossfader will not react in the software as u moving the faders on the mixer. Hope this helps
cool
