I second that ;)
Posted Fri 25 May 07 @ 11:05 am
i also have this problem. is it fixed anywhere. there is no way that i'm going to buy this software with a fault like that. i need it to run for a diner showin videos and slide shows. demo is great but leavin it on autoplay for a while is a big no no. where is the tech support???????
Posted Fri 01 Jun 07 @ 2:18 pm
its because ur not using 4.3 (solved in) , this is because the demo is 4.2
perhaps the 4.3 demo must be released
ps unoffical versions come with a few nasty surprises
Posted Fri 01 Jun 07 @ 2:28 pm
can this be guaranteed? i don't want to forkin out money on a product to find out the same thing happening! is numark cue the new version of it?
Posted Fri 01 Jun 07 @ 5:22 pm
it definately seems solved it doesnt happen to me or alf as you see here
we are on 4.3
numark cue is the same as vdj its just on cd and has some included videos
we are on 4.3
Posted Fri 01 Jun 07 @ 5:46 pm
thanks. do you know if numark cue is the new version or do i have to download updates after i buy it? do i have to pay for updates?
Posted Fri 01 Jun 07 @ 9:43 pm
numark cue users have the same update rights as vdj users
free for all updates
Posted Fri 01 Jun 07 @ 10:24 pm
well thanks. i'll have a think about it. can u reccomend a good setup for it?
Posted Sat 02 Jun 07 @ 3:43 am
whats ur style turntablist?
Posted Sat 02 Jun 07 @ 11:25 am
bit of everything. just mainly using midi controller now. club dj.
Posted Sat 02 Jun 07 @ 9:42 pm
currently usin pcdj. lookin for video support though. in the booth we've got the cdj's and the 1210's and a dac3 controller for pcdj.
Posted Sat 02 Jun 07 @ 9:43 pm
virtual dj pro and dac 3 will be fine
perhaps if u want a step up in control ,
you can use the 1210's
perhaps with the numark Virtual Vinyl Package
contains vdj pro (numark cue)
two control records and a pro soundcard
Posted Sat 02 Jun 07 @ 9:48 pm
can i upgrade at a later date to the vinyl control. or does it have to be that package??
Posted Sun 03 Jun 07 @ 3:38 am
not at all
you can mix and match
any dual stero input soundcard and the vdj timecodes will work
as you have a dac your good to go with vdj pretty much already :)
Posted Sun 03 Jun 07 @ 1:45 pm
cool, think i'll place an order on monday then hopefully the new version wont give me white noise. i have a maya 44 pci soundcard with 2 stereo in and out that should be able to work it i think.
Posted Sun 03 Jun 07 @ 3:49 pm
i just got my copy today. i've got it on autoplay test the now. i will let you know if the white noise pops up.
Posted Wed 06 Jun 07 @ 2:37 pm
well as tests goes. all ok. just buy the new version. it won't break the bank.
Posted Wed 06 Jun 07 @ 9:56 pm
good good
good good
Posted Thu 07 Jun 07 @ 12:44 am
Good to hear you got it sorted and welcome!!
Posted Fri 08 Jun 07 @ 9:08 am
Full version to the rescue :))
Glad you are happy now!
Posted Sat 09 Jun 07 @ 3:10 am
