Forum: VirtualDJ Plugins
Topic: DJC Mapper v2.0 - Page: 3
djcelPRO InfinityModeratorMember since 2004
Sorry i'm too tired tonight to have a look on my source code, i need a long night first
Posted Fri 25 Aug 06 @ 9:21 pm
Take your time, It works fine the way it is now, just thought I would let you know.
Posted Sat 26 Aug 06 @ 12:55 am
PuttePRO InfinityMember since 2004
To djcel
Have you got the time to look at problem with not saving the changes in the mapper ?
when i look in the download section of the mapper the date says Last update: Wed 4 Jan 06
Posted Wed 30 Aug 06 @ 3:35 pm
Yes this date is wrong, it's a bug when a teamer updates a plugin.
I will have a look tonight
Posted Wed 30 Aug 06 @ 6:22 pm
Djcel has anyone came up with a way to map the DAC2 the same way as the MK2??? Is it something that can be done?? I like the way the MK2 mapper is fully customizable. thanks Brian
Posted Thu 31 Aug 06 @ 8:43 am
ReTangoPRO InfinityMember since 2006
Djcel
First of all thanks for this excellent plug in. Your plug in is the only reason I upgraded from the MK2 VDJ Edition to the Pro Edition.
Just downloaded v4 of your plugin, and I found 2 non-critical bugs, which I would appreciate if you can fix next time you upgrade the plugin:
1) Plugin does not remember last setting, I have to load settings each time I open VDJ. This was working OK on v3.0, with the exception of the Rotary Speed Control, which always went back to 3 each time I opened VDJ
2) Some really weird things happen when I try to change the settings of some keys. For example, I use the MK2 pitch buttons to set_cue 1 and set_cue 2. I do the following:
Press the (-) button (of either deck),
Select "set_cue" from the drop down
set Value = 1
Pres "absolut (NO SIGN)" button
Press Apply
Until now everything ok
Then I select the (+) button and repeat the procedure above with Value = 2, and press apply
After this, when I select again the (-) button, it shows Value 2 instead of value 1. This happens with other buttons too. In order to set them right, i first press the relative buttons, then apply, then save, then change again to the absolute button, and somehow after many trials it works. This weird behaviour happens for me since v2.0 of your plugin...
it must be a minor bug in the code, since in v1.0 it worked perfect. Thanks again,
ReTango
Posted Sat 02 Sep 06 @ 6:24 am
1) Yes i'm working on it
2) Never noticed that, i will verify.
Posted Sat 02 Sep 06 @ 11:20 pm
1) I hope it's corrected now
the Rotary Speed Control: i will see that in the next version if i have time
2) Yes well found ( i have forgotten a case) and corrected too
I will upload the new one soon
Posted Sun 03 Sep 06 @ 2:48 am
Ok the new version is ready in downloads
Posted Sun 03 Sep 06 @ 3:11 am
Oups sorry everybody, it was not the good one. Now it's really corrected. Sorry for the delay
Posted Sun 03 Sep 06 @ 2:55 pm
ciocePRO InfinityMember since 2004
Posted Tue 05 Sep 06 @ 12:02 pm
@Cioce
Thank you again
Posted Tue 05 Sep 06 @ 2:55 pm
digowepHome userMember since 2006
;D
Posted Thu 07 Sep 06 @ 8:44 pm
CD-DJHome userMember since 2006
Thank you again
Moderated by Lady Cameron
Sorry CD-DJ no email address is allowed from a demo user
Posted Thu 14 Sep 06 @ 9:21 am
