Not sure why but M1 Pro should work just like M1 processor. As soon I open the application it gives me a "Stem Engine Error"
Please help.
Thank you,
Please help.
Thank you,
Posted Thu 17 Nov 22 @ 1:54 am
Works fine for me 😳
Posted Thu 17 Nov 22 @ 2:18 am
You ll need Mac OS 13 (Ventura) for realtime Stems 2.0
Posted Thu 17 Nov 22 @ 2:25 am
Am not sure how to post a screenshot so you guys can take a look.
Am running Mac OS Ventura 13.0.1
Posted Thu 17 Nov 22 @ 2:49 am
please contact support ( virtualdj.com/help ) they will be able to help you directly
Posted Thu 17 Nov 22 @ 9:25 am
Same error with Mac OS Ventura 13.0.1 and MacBook Pro m1
Posted Sat 03 Dec 22 @ 11:51 am
I'm having the same issue also, not able to find any guidance or support anywhere for this issue yet? Also running an MacBook Pro M1 on Ventura 13.0.1
Posted Mon 05 Dec 22 @ 9:26 pm
Fixed it by formatting and data restore
Posted Sat 24 Dec 22 @ 4:52 pm
Seems like alot of effort to get it to work, but that did the job! Thank you!
Posted Wed 28 Dec 22 @ 4:07 pm
Posted Thu 29 Dec 22 @ 12:51 am
Same issue with my wife's M1 imac. Completely fresh install of VDJ and stems taking forever.
Posted Thu 29 Dec 22 @ 8:52 am
It does have macOS 13?
Posted Thu 29 Dec 22 @ 7:52 pm
Good point, never thought of checking that. I don't think she's done anything with it apart from her business stuff so that probably is the issue :)
Posted Thu 29 Dec 22 @ 8:11 pm
Yes Keith, Ventura on a Mac M1 is a must for Stems 2.0.
Ventura is currently version 13.1.
Posted Thu 29 Dec 22 @ 9:51 pm
Thanks Les, will update tomorrow.
Posted Thu 29 Dec 22 @ 9:58 pm
All sorted now, original M1 imac creating stems for a 3 minute track in just under 15 seconds.
Think I'm going to wait to see what Macs come out in the spring, they're due for a refresh soon and I'm not in a hurry to upgrade.
My home machine is a 16" Intel (running Windows) but it's huge so I think the 14" hits the spot.
Posted Fri 30 Dec 22 @ 4:19 pm
No other solutions? I dont't want to format... I have just done a migration from macbook air M1 where Virtual Dj works well... I'm using:
VirtualDJ 2023 b7388 on Ventura 13.1
The options about Stems are the same
Posted Fri 30 Dec 22 @ 4:24 pm
Try renaming your settings.xml file (to find it go to settings> options and click the cog in the bottom corner) to see if VDJ creating a new one will fix the problem. If not you can just change it back.
Posted Fri 30 Dec 22 @ 4:42 pm
Keith, Are you actually considering coming over to the dark side????
Posted Fri 30 Dec 22 @ 5:21 pm
Potentially, but only for a DJ machine. All I would be running on it is VDJ and showXpress.
Have tried a couple of expensive Windows machines lately and I'm not impressed. Fundamental issues being the mess between dedicated and on-chip graphics and very poor battery life. The Apple M series chips sort that completely.
As for the mobile RTX cards I feel there's far more hype than substance.
Posted Fri 30 Dec 22 @ 6:11 pm
