No idea then, none of these messages are moderated.
Posted Mon 28 Feb 22 @ 12:34 pm
ADION
do you admit that you lied? otherwise, how did they half fix it
Show your video. That you are fine.
If there is no mixtrack pro, then at least a mouse on the skin wheel in 6839.
Also, how to make on the video. Prove that you do not lie as if everything is fine.
https://youtu.be/zwuf6jbcqf0.
Posted Mon 28 Feb 22 @ 1:01 pm
The problem that charliebuddrocker first showed is different, and that is fixed for the next update.
It can happen when using the scratch wave for scratching after using the jog wheel for scratching, but is not the same as the issue you experience when only using the jog wheel.
To investigate further why it happens on your computer I need
-The exact model of your CPU as can be found in task manager
-The resolution of your monitor
Posted Mon 28 Feb 22 @ 1:09 pm
IntelĀ® PentiumĀ® 2020M 2- core @2.40GHz
1366*768
all drivers update from official site.
But I think it's not about the processor, otherwise a lot of things didn't work and VDJ 8.4 too and Traktor, Serato
1366*768
Posted Mon 28 Feb 22 @ 1:41 pm
We are checking with some older controllers. It's likely related to the very low precision of the mixtrack compared to newer controllers, and mouse scratching might show the same issue on low resolution screens where the precision would also be lower, and thus on slow scratches the time between measurements becomes longer.
Posted Mon 28 Feb 22 @ 2:01 pm
I checked and Full HD 1920 x 1080 on another PC and another CPU.
Mixtrack Pro officially listed in VDJ.
Posted Mon 28 Feb 22 @ 2:09 pm
And the model number of that cpu?
Posted Mon 28 Feb 22 @ 2:12 pm
It looks like we're finally getting a proper audience from the devs..much appreciated
But i really think that the changes from the last good working build should be looked in closer...although there seems to be nothing decisive in the changelog
But if one build works perfectly at least for me,and then the build after produces the bug,how the bug can be controller on system related???
Posted Mon 28 Feb 22 @ 2:41 pm
Locodog
Core i-5 I don't remember exactly.
Dj Pari-M
maybe they added Stems and changed the scratch algorithm and code.
When you change "touchwheel" to "jogwheel", the algorithm feels different.
I want a new super better algorithm (like vinyl), but without bugs. :))
Dj Pari-M
Posted Mon 28 Feb 22 @ 2:53 pm
Dj Pari M
write your CPU and others
Posted Mon 28 Feb 22 @ 3:12 pm
Perhaps the bug arose when the scratch algorithm was improved so that the scratch speed did not change when the pitch slider was changed.
Posted Mon 28 Feb 22 @ 3:22 pm
user9298534 wrote :
Locodog
Yes its not something everyone remembers... and its so easy to find in windows..
press Windows + R key on the key board to open Windows RUN window first, then type msinfo32
then look in the System Summary for CPU info, and in Components > Display for your graphics specs
so you can easily screenshot for posting in the forum.
Posted Mon 28 Feb 22 @ 7:29 pm
System Information Report
Operating System Microsoft Windows 10 Home
Processor Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
Graphics Card Intel(R) HD Graphics 620 (1.0 GB)
Memory 5.0 GB Free (7.9 GB Total)
Monitor Generic PnP Monitor (1366 x 768 @ 59 Hz)
Disk Storage 663.6 GB Free (929.2 GB Total)
Audio Intel(R) Display Audio
Motherboard Dell Inc. (02DG7R)
Mouse Dell Touchpad
Keyboard HID Keyboard Device
Computer System
Computer Name DjPariLaptopDjMode
User Name Dj Pari(Dj Mode)
Organization N/A
Operating System
OS Name Microsoft Windows 10 Home
OS Version 10.0.19044
Product ID
System Up Time 28 Feb 2022 1:31:29 PM
Internet Explorer Version 11.789.19041.0
Microsoft DirectX Version DirectX 12
OpenGL Version 10.0.19041.1566 (WinBuild.160101.0800)
Registry
Maximum Size 4095 MB
Current Size 124 MB
Status OK
Central Processor
CPU Name Intel(R) Core(TM) i3-7130U CPU @ 2.70GHz
Number of logical processors 4
Code Name N/A
Manufacturer GenuineIntel
Current Clock Speed 2712 Mhz
Max Clock Speed 2712 Mhz
Voltage 0.9V
External Clock 100 Mhz
Serial Number
CPU ID Intel64 Family 6 Model 142 Stepping 9
Socket Designation U3E1
L1 Cache 128 KB
L2 Cache 512 KB
L3 Cache 3072 KB
Motherboard
Model 02DG7R
Manufacturer Dell Inc.
Serial Number /72P8WN2/CNWSC0087705LO/
BIOS Name 2.18.0
BIOS Vendor Dell Inc.
SMBIOS Version 2.18.0
BIOS Date 15 Dec 2021
BIOS Features
PCI is supported Yes
Plug and Play is supported Yes
BIOS is Upgradable (Flash) Yes
BIOS shadowing is allowed Yes
Boot from CD is supported Yes
Selectable Boot is supported Yes
EDD (Enhanced Disk Drive) Specification is supported Yes
Int 13h - Japanese Floppy for NEC 9800 1.2mb (3.5, 1k Bytes/Sector, 360 RPM) is supported Yes
Int 13h - 5.25 /1.2MB Floppy Services are supported Yes
Int 13h - 3.5 / 720 KB Floppy Services are supported Yes
Int 13h - 3.5 / 2.88 MB Floppy Services are supported Yes
Int 5h, Print Screen Service is supported Yes
Int 9h, 8042 Keyboard services are supported Yes
Int 14h, Serial Services are supported Yes
Int 17h, printer services are supported Yes
ACPI supported Yes
USB Legacy is supported Yes
Smart Battery supported Yes
Memory Resource
Total Memory 7.9 GB
Used Memory 2.8 GB
Free Memory 5.0 GB
Memory Usage 36%
Physical Memory
Memory Bank BANK 0
Description Physical Memory 0
Device Locator DIMM A
Capacity 8.0 GB
Speed 2400 Mhz
Manufacturer 04CB000080AD
Data Width 64 bit
Memory Type Unknown
Form Factor SODIMM
Disk Drives
Name TOSHIBA MQ01ABD100
Media Type Fixed hard disk media
Capability 931.5 GB
Interface Type IDE
Partitions 8
Total Cylinders 121601
Total Heads 255
Total Sectors 1953520065
Total Tracks 31008255
Tracks Per Cylinder 255
Bytes Per Sector 512
Sectors Per Track 63
S.M.A.R.T Support Yes
IDE Controller
Name Intel(R) 6th Generation Core Processor Family Platform I/O SATA AHCI Controller
Manufacturer Intel Corporation
Status OK
Video Adapter
Name Intel(R) HD Graphics 620
Video Processor Intel(R) HD Graphics Family
Video Architecture VGA
DAC Type Internal
Memory Size 1.0 GB
Memory Type Unknown
Video Mode 1366 x 768 x 4294967296 colors
Current Refresh Rate 59 Hz
Driver Version 27.20.100.9664
Driver Date 1 Jun 2021
Monitor
Name Generic PnP Monitor
Screen Height 768
Screen Width 1366
Status OK
Wi-Fi
Product Name Qualcomm QCA9565 802.11b/g/n Wireless Adapter
Service Name athr
Manufacturer Qualcomm Communications Inc.
MAC Address 90:32:4B:4E:EA:AB
Ethernet
Product Name Realtek PCIe FE Family Controller
Service Name rt640x64
Manufacturer Realtek
MAC Address NULL
Sound Device
Name Intel(R) Display Audio
Manufacturer Intel(R) Corporation
Status OK
Sound Device
Name Realtek Audio
Status OK
Sound Device
Name VB-Audio VoiceMeeter VAIO
Manufacturer VB-Audio Software
Status OK
Sound Device
Name VB-Audio VoiceMeeter AUX VAIO
Status OK
Mouse
Name Dell Touchpad
Manufacturer Synaptics
Buttons 0
Status OK
Mouse
Name PS/2 Compatible Mouse
Manufacturer Microsoft
Buttons 0
Status OK
Keyboard
Name HID Keyboard Device
Description Enhanced (101- or 102-key)
Function Keys 12
Status OK
Keyboard
Name Standard PS/2 Keyboard
Function Keys 12
Status OK
Keyboard
Function Keys 12
Status OK
USB Controller
Product Name Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Manufacturer Generic USB xHCI Host Controller
Protocol Supported Universal Serial Bus
Status OK
Mouse Dell Touchpad
Computer System
Organization N/A
Operating System
Product ID
Registry
Current Size 124 MB
Status OK
Central Processor
Code Name N/A
Voltage 0.9V
Serial Number
L1 Cache 128 KB
L2 Cache 512 KB
L3 Cache 3072 KB
Motherboard
Model 02DG7R
BIOS Name 2.18.0
BIOS Features
ACPI supported Yes
Memory Resource
Total Memory 7.9 GB
Used Memory 2.8 GB
Free Memory 5.0 GB
Memory Usage 36%
Physical Memory
Memory Bank BANK 0
Capacity 8.0 GB
Speed 2400 Mhz
Data Width 64 bit
Memory Type Unknown
Form Factor SODIMM
Disk Drives
Capability 931.5 GB
Interface Type IDE
Partitions 8
Total Heads 255
IDE Controller
Status OK
Video Adapter
DAC Type Internal
Memory Size 1.0 GB
Memory Type Unknown
Monitor
Screen Height 768
Screen Width 1366
Status OK
Wi-Fi
Service Name athr
Ethernet
MAC Address NULL
Sound Device
Status OK
Sound Device
Name Realtek Audio
Status OK
Sound Device
Status OK
Sound Device
Status OK
Mouse
Name Dell Touchpad
Buttons 0
Status OK
Mouse
Buttons 0
Status OK
Keyboard
Function Keys 12
Status OK
Keyboard
Function Keys 12
Status OK
Keyboard
Function Keys 12
Status OK
USB Controller
Status OK
Posted Mon 28 Feb 22 @ 10:04 pm
@Pari M: Which controller did you use?
Posted Tue 01 Mar 22 @ 6:57 am
he wrote about the controller Pioneer DDJ SB3
http://www.virtualdj.com/forums/236273/VirtualDJ_Technical_Support/Weird_jog_bug.html?page=1
Posted Tue 01 Mar 22 @ 7:46 am
