think I've a fix, check pm
Posted Wed 11 Mar 20 @ 11:19 pm
Could you PM me too please.
Posted Thu 12 Mar 20 @ 7:36 am
The controller sends MIDI notes properly
<map value="DECK_1" action="deck 1 leftdeck" />
<map value="DECK_3" action="deck 3 leftdeck" />
<map value="DECK_2" action="deck 2 rightdeck" />
<map value="DECK_4" action="deck 4 rightdeck" />
The problem here derives from the fact that VirtualDJ two decks skin is... a TWO DECKS skin! :P
The user wants to use decks 3 & 4 instead of 1 & 2.
And while some time ago that was possible with default 2 decks skin it's not anymore.
In order to get this "working" there are only 2 possible solutions:
1) Edit the default 2 decks skin to show current left/right deck instead of fixed deck 1 and 2
2) Edit the mapper so that you remap the action of deck 3 to deck 1 and deck 4 to deck 2
In this case a simple action like "pioneer_play" becomes:
action_deck 1 ? deck 3 pioneer_play : action_deck 2 ? deck 3 pioneer_play : action_deck 3 ? deck 1 pioneer_play : deck 2 pioneer_play
There is also a third solution:
Use another skin that has left/right (or swap) logic.
Posted Thu 12 Mar 20 @ 7:40 am
I'm working on 1st, user is actually using pro & performance.
Posted Thu 12 Mar 20 @ 8:29 am
Works fine already, dont have to change or do anything ... :) ..at least it should
With a 4 deck controller connected, VirtualDJ has 4 decks, even if using 2-deck layout
Posted Thu 12 Mar 20 @ 1:56 pm
it's the deck X leftdeck from the controller command that is screwing it up rune.
I've tweaked the default skin so it only shows C&D for him to test
Posted Thu 12 Mar 20 @ 2:01 pm
Hey locodog. Can you do one that only has deck A&B too? You’d want laptop one to stay on A&B and Laptop 2 to stay on C&D.
Posted Thu 12 Mar 20 @ 6:54 pm
Just make a custom button or keyboard key with action : deck 3 leftdeck & deck 4 rightdeck ...
And if you want automatic, just add the same action to oninit entry in the keyboard mapper
Or alternatively, just need to add 2 lines at the skin xml
<onload action="deck 3 leftdeck"/>
<onload action="deck 4 rightdeck"/>
Posted Thu 12 Mar 20 @ 6:59 pm
I'm not sure who's confused here, I know I am.
the ddj1k in question has 2 laptops connected to it, users want machine 1 to only control decks 1 & 2, machine 2 deck 3 & 4
because the 1k sends a invert_deck command when it does it's HW shift and the default skin 2 deck being left/right the dj in waiting will have 2 decks on screen that aren't his
maybe it doesn't need a skin tweak, maybe just a rsi,
no it'll need this removing also
<nbdecks value="2" condition="var_equal '@$4decks' 0"/>
Posted Thu 12 Mar 20 @ 7:37 pm
Not needed for machine 1, the two deck skin forces the number of decks to 2 so you can only get A&B
check your msgs
Posted Thu 12 Mar 20 @ 7:47 pm
Should be no need for that. The DDJ-1000 is a 4-deck controller that (at least in theory) should override any such skin settings. Explicitly setting 4 decks, and skin not "forcing" 2 decks
Posted Thu 12 Mar 20 @ 8:41 pm
Went with the skin tweak, rsi forcing 'side'deck left a chance for things to go wrong,
made pro 1&2 and pro3&4, also did the same with performance
gmedia is testing but first reports are, 'all good'
Posted Sun 15 Mar 20 @ 3:39 pm
So far it is EXACTLY what I needed. I can have all 4 decks active and visible at once with never any "muted" decks. Since the DDJ-1000 only has two jog wheels (which is perfect for me as a mobile), you just need to press the one "deck change" button to toggle between A/C or 1/3 and B/D or 2/4. Otherwise, you can just use your mouse or touch screen and keep the jog wheels locked to A/C or 1/2.
There are many reasons to have 4 active decks. The major reason I use two PC's is for when something goes wack with one of them (which happens to ANY electronic device, Apple and PC alike).
Thank you so much man!
Chris
Chris
Posted Sun 15 Mar 20 @ 5:00 pm
