For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Problem with Stanton scs.1D and 8.2
Hello, Ive got a Stanton SCS.1D which worked with no issues until the first 8.2 build. If I go back to the 8.0 build it works fine but on any 8.2 build after about an hour worth of djing, when I access the playing track using the motorised platter it jumps through the track (skipping or moving right to the end, you cannot stop or drag the track in vinyl mode and if you to many times to causes VDJ8 to crash
Posted Wed 03 Jan 18 @ 4:21 pm
