Forum: VirtualDJ 8.2 Technical Support
Use this forum to report any bug, questions or comment related to the latest version of VirtualDJ 8.2.
Forum Guidelines
(NOTE: VirtualDJ 8.2 is continuously updated, so many older topic on this forum are most probably already fixed in the current build)
Topic: How to forward or backward a track using keyboard shortcut key?
Hi there,
I have configured the "ENTER" button to load the track and now I want to come in the middle of the song without using mouse click, how can I forward or backward the song using keyboard shortcut key?
PS: I have not set any cue for the song.
Posted Tue 07 Nov 17 @ 5:34 am
You can map goto
So for instance map goto -4 for CTRL+G and goto +4 for ALT+G
Then CTRL+G wil be rewind and ALT+G will be fast forward
EDIT:
If you never mapped anything befor, it's simple for simple commands
Just go into settings->controllers->keyboard
Then go to the key field and click what you want to map. Like: CTRL+G
Then go to the action feld and put in the script. Like: goto -4 (No spaces or new lines in the end)
Click save, and it works right away.
Like this:
Posted Tue 07 Nov 17 @ 5:44 am
Thanks for your help.
Posted Tue 07 Nov 17 @ 8:33 am
