Post here the features you would like to see developed in VirtualDJ in the future.
Topic: Scripts you'd like to see.(no matter how barking mad) - Page: 3
DJEMANGPRO InfinityMember since 2011
save artwork to tag in pads is there a script for that
Posted Tue 18 Jul 17 @ 9:44 pm
djkzPRO InfinityMember since 2005
i don't understand your request. can you give me an example.
Posted Wed 19 Jul 17 @ 3:47 am
hi i have been struggling with the MC7000 and the 4 buttons 1 2 3 4 on each side of the deck manual says one side copys the other.. well i dont want that
i want to say left deck 1 - Camera , 2 ShowLogo ,3 does whatever , 4 does whatever. and then the Right Deck does visuals but different ones all to the main output screen not a copy and not an effect on that deck.. least something id like to try
Posted Wed 02 Aug 17 @ 11:55 am
locodogPRO InfinityModeratorMember since 2013
You want to script something like this
device_side 'left' ? action for left : action for right
Posted Wed 02 Aug 17 @ 5:17 pm
i not sure if you see
but here is my deck
http://virtualdj.com/manuals/hardware/denon/mc7000/layout.html
and this is the buttons i wanna change
http://virtualdj.com/manuals/hardware/denon/mc7000/layout/effects.html
shows you 55 that has 4 buttons i want each one to do something different
so there is 4 buttons left and 4 buttons on right and i dont really wanna copy just 8 buttons doing something different
but i would also try this copy but to get the FX to work i played with it kinda if i pressed 1 then 3 4 would light up so it didnt work right
Posted Thu 03 Aug 17 @ 11:59 am
im guessing you guys stumpped on my situation for my FX buttons i still trying to fiddle with it but cant get it to work right for all 8 buttons to do whatever and 2 or 3 do video things to the main output window
Posted Wed 09 Aug 17 @ 4:50 pm
LEDs are a different matter show me the script you tried using
device_side
Posted Wed 09 Aug 17 @ 5:25 pm
I'd like to have the option that VDJ automatically sort cue in a songs in chronological order, like its possible in Serato.
Posted Sat 25 Nov 17 @ 7:52 pm
I'm sure that's an option that's been there since pre 8.1 days,
I'll check once at my machine.
Posted Sat 25 Nov 17 @ 11:42 pm
Can I get the std filter to run in "LFO mode" (as in: go up and down while a button is pressed)
Or possible script it:
Locodog, I've modified this from an old v7 discussion (regarding volume):
repeat_start 'wait' 50ms & var 'up' ? filter +1% & filter 100% ? set 'up' false : set 'up' true : filter -1% & filter 0% ? set 'up' true : set 'up' false : set 'up' true
But it only goes "down", and then stops - and it never ends (makes sense since there is nothing in the script to end it)
Am I missing something obvious that makes it much simpler to do than this?
Posted Mon 12 Mar 18 @ 1:07 pm
set 'up' false :
set 'up' true :
set 'up' true :
set 'up' false :
set 'up' true
Looks ok, i don't usually use true and false I use one and zero, change the time to maybe a second and crank the filter up manually to 95 percent, then use the var_list to check "up" is toggling.
Posted Mon 12 Mar 18 @ 5:12 pm
It worked with one and zero :)
I ended up with:
up ? repeat_stop 'wait' & filter 50% : filter 50% & repeat_start 'wait' 75ms & var 'up' ? filter +5% & filter 90% ? set 'up' 0 : set 'up' 1 : filter -5% & filter 10% ? set 'up' 1 : set 'up' 0 : set 'up' 1
Thanks!
Posted Tue 13 Mar 18 @ 12:08 am
Page : [<<] [<]
