You might want to try lowering the master within the VDJ interface to avoid any clipping. You might also want to change the ASIO driver bit sample rate to improve the audio quality.
Posted Wed 16 Jul 14 @ 11:18 am
I think you should wait, this is release season and Numark has the first of the season.
Posted Wed 16 Jul 14 @ 1:47 pm
Thanks will check the setup in Virtual DJ. where is the master Vol....
Posted Wed 16 Jul 14 @ 11:07 pm
original I had a IDJ2 and loved the sound it. Good point it could be the files I'm using.
Posted Wed 16 Jul 14 @ 11:10 pm
can anyone tell me if NUMARK IDJ2 controller not the idj2go will work with virtual dj software
Posted Thu 17 Jul 14 @ 11:35 am
Maybe, you have to go in option in VDJ8, controllers section, eight click on the small window where there is keyboard and choose to see all controllers than research if there is your controller inside the controllers list.
Posted Tue 22 Jul 14 @ 9:58 pm
Look [url=http://www.virtualdj.com/wiki/VirtualDJ%20Controllers.htmlhere[/url].
Posted Wed 23 Jul 14 @ 4:53 pm
purchased the DBX Driverack PA2 to help clean up the sound. I have heard a lot about them.
Posted Thu 24 Jul 14 @ 12:43 am
