Build 2245 (05/07/2015)
-Fix problem writing certain mp3 tags
-cdg karaoke tracks can be rendered in 16:9 aspect ratio
-zoom letterboxing option allowed for karaoke tracks again
-Fix multi-window skin problem with windows that are initially hidden
-get_time_sec 'absolute' fixed
-deck x linein initializes that deck if it wasn't available yet
-get_rotation_slip added
-slip position added to gemini waveform
-no slip interference when scratching while pausing
-shift+drag can be used to move folders
-fix skinRhythm couldn't be on a panel that moved
-fix netSearch
-fix netSearch
Posted Wed 06 May 15 @ 7:22 pm
          Build 2265 (05/19/2015)
-fix get_beatgrid action to match description
-fix decoding wma files when output samplerate is 192kHz
-fix for numark nv automatic deck selection of displays being wrong
-support for custom mixer order for 4 deck controllers
-new action effect_slider_active
-Fix video drawn not pixel-perfect in some cases with DirectX
-effects_used 'deck' and effects_used 'master' actions
-Fix prelisten crash when using prelisten after deleting or moving a file previously prelistened
-Fix browser_scroll not scrolling from correct location after dragging a song to a different location
-new action get_playlist_time
-Escape key works to cancel security load window
-Fix possible issue reading remix and remixer field from Ogg and Flac tags
-Fix check to ensure VirtualDJ is visible on screen
-Fix performance problem with Reverb and Phaser when track paused
-Fix popup alerts from config window hidden on Mac
-Fix config record file selector hidden on Mac
Posted Wed 20 May 15 @ 5:37 am
          Build 2282 (05/24/2015)
-search action can accept action queries using backtick
-fix case sensitivity for browsing unzipped skins
-in single-touch scroll mode, 2 fingers can be used to drag a song
-new vdjScript keyword: isok
-new vdjScript action: mix_and_load_next
-Fix using hot_cue action in stutter mode with keyboard
-Fix recurse not preserved when dropping a file on a virtual folder in the tree list
-Fix 'effects_used "deck"' action
-Fix for relativetouchslider option on HID sliders
-Fix for rhythm wave sometimes not fully drawn
-Better results for netSearchAudio
Posted Mon 25 May 15 @ 11:34 am
          Build 2305 (6/8/2015)
-new ContentUnlimited Audio core catalog
-new VDJRemote v8 on iOS and Android
-Fix for wide-screen karaoke file rendering cutting off part of the side
-Mixer order used for audio channel routing
-playlist_load_and_remove and playlist_load_and_keep actions use the first item from the list instead of the selected to match their description
-splitHeadphones master volume at 100% by default
-fix for hercules dj controller custom buttons not showing effects anymore
Posted Mon 08 Jun 15 @ 6:28 pm
          Build 2325 (06/15/2015)
-New core catalog for ContentUnlimited Audio
-param_1_x action added
-browser_remove action added
-Fix for cdg widescreen playback
-improved using 2 timecodes with 4 decks
-automix skip/mix_now length can be customized (automixSkipLength option)
-BPM editor can be closed using escape key
-exclude playlists from recursion in system folders
-some fixes to automatic deck assignment for controllers
-Fix reset sort order also hiding virtual folders
-Effect ini file is stored for plugin instance that was last modified
-Fix options window at 250% dpi
-Slideshow sorted by filename
-Cover engine speed-up when loading from cache
-Fix possible plugin engine crash on close
-Rewire not re-initialized on each scan to prevent audio dropouts
Posted Mon 15 Jun 15 @ 3:40 am
          Build 2338 (06/21/2015)
- final ContentUnlimited Audio catalog
- new action browsed_file_reveal to open OS file manager to file selected in browser
- new action set_browsed_file_bpm to set or adjust the BPM of the file(s) selected in browser
- fix dialog hidden for manually adding remote IP on Mac
-Fix select logo from options on mac causing selection dialog to appear behind options window
-Fix logging of found sysex id
-Fix 'ignore' folder not ignored by effect_select +1/-1 correctly
-POI editor can be closed using Escape key
-Fix camelot key search
-Fix being able to move internal video transitions into a subfolder
-Add string parameter "random" to video_transition_select to allow for a manual random transition selection
-selectPlugin with float index uses entire plugin list
-Fix mapper KEY disapearing on selection for some controller mappings
-MIDI definitions without output channel defined can send on the same channel as incoming messages instead of fixed to channel 0
-vdjRemote browser can browse and add to sidelist, karaoke or automix lists (needs vdjRemote 8.0.2334 or higher for full functionality)
Posted Sun 21 Jun 15 @ 10:10 am
          Build 2348 (07/12/2015)
-Fix sorting by last modified date
-Fix problem writing mp3 id3v2.2 tags
-Fix problem writing mp3 id3 tags when tag size needs to be increased
-CDJ nexus colored waveform
-revert default channel for midi out
-add remix to file names when caching cu files
-improve tag reading for cached cu files
-get_deck_color "absolute" action added
-fix possible click sound at end of automix
-Fix problem writing id3 cover when tag needs to be increased in size
-Track cleaner closes prelisten player on close so that song can be reloaded properly
-fixed update popup appears behind config window (if open) on Mac
-new video transition 'additive' which is useful for video fading with the volume faders
-Fix possible deadlock while downloading
-Save root in playlists to be more compatible with other programs
-Fix netsearch audio files getting video icon sometimes when saving to cache
-Global sampler focus for controllers with 2 sides but single sample controls (use "deck master sampler_loop +1" for example to use)
-samplerVideoVolumeLink option added
-Fix POI editor prelistening producing buzzing sound with loop set in seconds
-Fix crash when adding file to automix twice from remote
-Fix mic not included in headphones output when headphones mix is on
-Touch wheel backward/forward spin threshold configurable
-seek action stops before beginning and after end of track
-Content Unlimited search folders always show results regardless of filters
-Scrolling using jog wheel works similar to scrolling using browser_scroll
Posted Mon 13 Jul 15 @ 6:55 am
          Build 2352 (7/20/2015)
-Jog returns to wheel mode when loop disabled and it was in loop move mode
-zero parameter for midi pitch slider definition
-Escape binary characters in database xml to be compatible with external xml tools
-Auto-generate video edit by dropping video file on video preview of audio file
-Fix some old xvid video's not playing back correctly
-browser_sort action accepts + in front of column name to force ascending sort
-scratching on the skin allows backspins
-New script command playlist_randomize_once that performs a 'Shuffle Once' on the playlist
-Add file selector to iTunes database file setting
-Fix Additive transition on Mac
Posted Sun 19 Jul 15 @ 7:13 pm
          Build 2362 (07/27/2015)
-Update chinese translation
-faster sorting on usb/network drives
-force content shown in search content unlimited folders even with filters active
-New option autoSideview to have sampler_bank option switch sideview to sampler or not
-Fix sample syncing with variable bpm tracks
-fix bug in keyengine
-Copy database info when copying a folder
Posted Sun 26 Jul 15 @ 11:04 pm
          Build 2369 (2/8/2015)
-Fix video fading during Glass and Grid transitions
-Fix flicker at start of Shatter and Droplets transitions
-fix search for upper-case russian characters
-fix some possible automix lock issues
-with splitHeadphones enabled, headphone volume controls both sides
-Fix possible crash when a download is canceled
-browser_sort '+bpm' can be correctly queried (for leds)
-Fix effect list not showing up for LE mode
-Skin drop zones follow draw order
-Split headphones headphone channel is mono mix of headphone instead of only left channel
-Fix some video samples not returning to start correctly
-Fix lottery effect image list not resetting when selecting a new folder
Posted Sun 02 Aug 15 @ 7:05 pm
          Build 2378 (08/10/2015)
-Compatibility with windows 10
-browser_sort '+bpm' fix
-2-deck skin fix for rhythm wave left/right deck logic
-Make effect GUI buttons more obvious when active
-New video effect 'Shake'
-New VDJScript command undo_load to unload the current track and reload the previous track
-Fix possible crash after lost sound card is available again
-autocue mode cue/skip silence added to skip silence when no cue is available
-Fix rhythm wave not updated on left side when starting to load from middle of song
-Fix green line when using dxva on some videos
-Fix on screen keyboard not working correctly on windows 10
-fix custom browser lists not updating correctly when switching from list to grid view
-source="karaoke" added for filelist skin object
-param_equal accepts 2 strings to compare query action with a string (example: param_equal "`get_browsed_song 'type'`" "audio")
Posted Mon 10 Aug 15 @ 1:00 am
          Build 2438 (09/06/2015)
-Fix slideshow sometimes getting stuck on black image when removing an image
-edit_singer fixed for custom browsers
-loop_roll can now be used on videos as well (switch on in plugin settings, or using 'loop_roll video' action)
-fixed loop action not always working correctly when loop size defined in milliseconds
-Add video option to slicer (switch on in plugin settings, or using 'slicer video' action)
-saveUnplayedToSidelist option will no longer add a track to the sidelist if it is already there
-items in the sidelist can now be added to the automix list directly by using their context menu
-fix potential crash in liveFeedback
-prevent history file to grow too much when no internet connection
-Performance improvement for track scan
-Fix wasapi audio glitch at startup in some cases
-Fix elastique glitch on first pitch change
-Fix some potential noises when using pitch quality 2
-Master VU meter reflects master_balance
-Fake Master no longer affects master volume
-Fix video slideshow not progressing to next videos when duration is set to full
-when controller is defined with 1x1 sample pads, the selected sample (sampler_select) is highlighted on the skin
-cda audio track always reloaded to ensure correct file when inserting a new cd
-new VDJScript command 'browsed_file_rename' to rename the currently selected file in the browser
-new VDJScript command 'browsed_file_analyze' to (re)analyze the currently selected file(s) in the browser
-new VDJScript command 'reanalyze' to reanalyze a file loaded on a deck
-'No 3/4' option added to Loop Roll to skip the 3/4 loop roll when using the slider parameter
-new setting quantizeLoop (VDJScript quantize_loop) adjusts loop positions to snap to a quantized grid position
-new setting quantizeSetCue (VDJScript quantize_setcue) adjusts the setting of cue points to snap to a quantized grid position
-setting smartCueQuantize renamed to globalQuantize
-Fix incorrect aspect ratio on some wmv's
-Fix potential crash in sound config window
-15% performance improvement on launch speed
-fix potential problem when upgrading to windows 10
-Fix b2389 regression bug causing sound and waveform to get out of sync in some cases
-fix for temporary cue preview when quantizeSetCue enabled
-fix login window hidden behind config window on Mac
-fix seeking in track edits for preview
-Fix position shown in track cleaner
-Fix regression causing reduced sound quality when mastertempo is disabled and pitchQuality is 2
-Fix cue_stop crash (#2399 regression)
-Improve scratch sound quality
-Add videoCreateLinkOnDrop option
-Fixed bug with removing items from file list when some items are still selected
-Fix filter folder 'User 1 is text'
-Improve use of colors in filter folders ('color=red' and 'color=255,0,0' both work)
-Remember last path used for Copy To or Move To
-Fix delay between sound and waveform after seeking in mastertempo quality 2 (#2425 regression)
-Fix green on some videos with dxva
-Fix possible analyzer crash
-Fix unable to rename virtual folder with no files in it
-Fix custom context menu crash
-Fix detailed waveform colors slightly off and possible crash
-Fix possible crash in sync action
-Fix possible crash in Camera plugin
-Fix video getting stuck in some cases when using loop roll with video enabled
-Fix autogain not applied sometimes when using load & play in a single action
-Fix action auto-complete preferring synonyms
-Track Cleaner now correctly shows and prelistens modifications
-Some performance optimizations
-Fix possible crash in skins using racks
-Fix crash when generating a video edit by drag&drop
-Fix possible audio encoder crash
-Fix green videos when dxva is enabled on nVidia
Posted Tue 08 Sep 15 @ 3:19 pm
          Build 2441 (09/13/2015)
-Auto_crossfade and video_transition can move to a specific location
-Prelisten start position stored in config
-Fix crash on endless recursion in browser
-Fix deleting custom mapper
-Fix loop_exit jumping to bad slipmode position when no loop was set and looproll mode was on
-Fix mac crash when loading or analyzing a file with corrupt length tag
-Fix mac showing certain notifications twice
-Fix Cube and Satellite transition position off
Posted Wed 16 Sep 15 @ 3:12 am
          Build 2465 (10/5/2015)
-sampler_group_mute action added
-ONEXIT support for keyboard mapper
-Fix images in samplebank not showing on video output if samplebank was loaded before video engine initialized
-Fix loop_exit jumping to slip mode position when no loop is active
-Fix possible track edit crash
-Fix possible lock up of loading songs after downloading content unlimited song to cache on mac
-Fix video memory leak
-Fix playback of some bad mpg files
-Fix getRemixFromFilename
-Fix crash seeking some cdg files
-Fix memory leak when reloading skin
-Faster response of automix_skip
-Fix paths on database stored incorrectly for files on other drives when the drives are not writeable
-Fix database not set to not writable when permissions don't allow it
-Fix browser file list for vdjRemote in sidelist view
Posted Sun 04 Oct 15 @ 9:10 pm
          Build 2483 (10/11/2015)
-Reverb and Echo have switch to enable trailing stop when disabling the effect
-Feedback and Highpass parameter added to flanger
-Read Serato track colour from tag when cues are read
-Clone also clones loop
-Fix automix_skip when deck is paused while automix active
-Fix cue_name action problem in some cases
-Fix possible plugin issue when showing effect gui
-Fix possible track cleaner crash
-Fix possible video crash
-Fix detection of ASIO drivers with REG_EXPAND_SZ type (like Rane ASIO driver)
-Fix some problems with bad vga drivers
-Fix cdg using scroll preset
-Fix advanced audio channel selection hidden behind config window on Mac
-Fix renaming playlists and only changing the case
-Fix video flickering in track edit when source length was 0
-Fix possible batch analysis lock up
-Fix regression crash when undocking effects
-Fix scratch/size cursors not working anymore after drag (regression)
-Reverb trail continues a bit longer
-Fix ape file playback
-Fix retina regression on mac
-Fix main window on mac getting behind dock when maximized and restoring video window from maximized
Posted Thu 15 Oct 15 @ 8:18 am
          Build 2522 (10/20/15)
-Fix rare mac crash when scanning audio devices
-Fix rare tag editor crash
-Fix wma lossless playback
-Fix rare lockup on some vst effects
-added option 'Ignore' to move internal plugins to ignore list
-Add custom mapping option to mapper list when no mapper is present to make it more clear how to create a new mapper
-Options expanded by default when advanced options disabled
-Fix Title video effect showing previous song when started
-Add frequency selection to Shake video effect
-Fix ASIO issue when using inputs and ASIO samplerate different from internal samplerate
-Update for Chinese translation to include skin translation
-Implemented saved loops with fixed numerical slots
-New VDJScript command saved_loop which saves or loads and jumps to a saved loop
-New VDJScript command saved_loop_prepare which saves or loads a saved loop
-Fix possible crash in set_browsed_file_bpm
-Fix systray notifications in windows 10
-Fix undocked plugin windows on mac
-fix pen input
-invert_deck action added to swap left deck between deck 1 and 3, or right deck between deck 2 and 4
-left and right added as deck assign option for single deck controllers
-Existing saved loops with no slot and no name assigned slot number automatically so they can still be accessed
-fix pen input
Posted Tue 03 Nov 15 @ 5:46 pm
          v8.1 - build 2582 (2015-11-20)
-Fix slicer length not restored on restart
-Fix systray icon not removed on exit on windows 10
-Add 'Content Unlimited' text above content unlimited search results
-Fix issue with random video transition getting stuck on Droplets transition
-Add 'Restore' option for internal plugins moved to Ignore folder
-browser_sort action updates second order sort (same as clicking column headers)
-fix invert_deck for deck 4
-fix bug when adding a recursive folder with filter folder inside to sideview
-fixed deep recursion bug
-browser_scroll can be used with percentage (browser_scroll 50%)
-fix possible lockup on internet downloads
-sampler_group_volume ghost slider fix
-Genres can also be delimited by / now, not only ;
-Fix for HID encoders when overflowing
-Midi bar output accepts boolean as well (for on/off support)
-New VDJScript verb 'is_audioonlyvisualisation' which will return true if the deck currently has the audioOnlyVisualisation active
-Fix empty picture sometimes when video is loaded but busy seeking
-Fix empty picture sometimes after seeking video back to beginning
-Allow RPM to be set to '4 beats' so that one rotation takes exactly 4 beats
-Prevent song from stopping when loop is set past the end of the song
-Saved loop commands with no parameter now act on the first saved loop slot
-Can no longer save a loop with ID 0
-Fix file deletion on mac os x 10.7
-Loop position remains quantized when automatically moved whilst quantize_loop and loopAutoMove are both enabled
-Fix some rare crashes when refreshing the effect list
-Fix crash when dragging a delimiter from cover flow
-Fix video editor crash
-Fix memory leak when aborting song load of a non-analyzed song
-Fix config window saying 'not logged in' when user was logged in but had no user name (google login)
-Fix sound setup showing warning triangle when user has Plus license and external mixer output, even though license supports it
-Fix rare audio crash when soundcard samplerate is different from internal samplerate
-Fix crash using controller to switch through browser lists
-Add support for jog wheel enable bit for HID controllers (for Pioneer CDJ's)
-Fix skin button getting stuck in mouse down state if it closes an effect interface
-Fix various messageboxes stuck behind config window on Mac
-Fix loop_select on encoders when moving very fast (+2/-2 as parameter)
-Fix factory default mapping not selectable
-Shift all cues excludes beatgrid
-Slidshow can play video samples
-Sample dropped in list view starts at first row instead of second
-Serato root folder can be re-ordered
-Shazam integration
-Improved cloudlist features
-Shazam integration
Posted Fri 20 Nov 15 @ 12:14 pm
