Hello everyone,
This is my 1st post on the forums!
I have an LG P1PRO Express dual Laptop (KP02hs model) And a DDJ ERGO-V controller
Laptop Basic specs:
Core 2 duo t 5600 1.83Ghz
2Gb DDr2 667 Ram
Ati mobility radeon x1400
320Gb Sata c(AHCI MODE) HDD
In Both Windows Xp and Windows 7 (In windows 7 its worse) I have crackling noise and songs are skipping.
I thought it was a letency problem but it isn't! DPC Latency Utility shows that everything is fine!
- I've already tried disabling devices in Device manager and all un-necessary services and programs but still the same problem..
-Latency settings in asio configuration utility tested in various modes but...nothing (current config 512samples 16bit 4 kernel buffers)
- I've tried other software such as traktor pro 2 and serato dj intro much less crackling noise but still the same problem
-Cpu meter never exceeds 80% when loading to deck and when its not loading anything during playback its about 20%
So.. i've uninstalled my ati x1400 drivers and tested all 3 softwares at a resolution of 1024x768@32bit and the problem disappeared!!
i've tried diffrent versions of the drivers but still the same problem!!
when i'm using a custom skin it gets worse!! so.. I modified a skin as a test and completely disabled rhythm on top and it gets better but functionality now is much less..
I'm only mixng mp3's not video and i'm starting to think that my x1400 can't process the graphics of virtual dj could that be true?
Any suggestions on what i can do to fix it?
Laptop Basic specs:
2Gb DDr2 667 Ram
Posted Fri 15 Mar 13 @ 6:31 pm
Please do not post the same message or question more than once.
You have already asked this question in the following topic: http://www.virtualdj.com/forums/104382/Hardware_Technical_Support/PIONEER_Hardware_Products_%28Setup__Solutions__Fixes__Issues__etc_%29.html
[Duplicate topic closed]
Posted Sat 16 Mar 13 @ 3:40 pm
