Forum: Old versions
Topic: Mapping for NUMARK MIXTRACK? - Page: 2
BlulitePRO InfinityMember since 2009
S0nic2 wrote :
I have virtual dj 7.0 pro i cant hear music on mix cue, i wont to hear two songs in same time on mix cue, everything work fine only mix cue make me problems, how can i hear two songs in same time on cue mix, thanks
as support says, please register your serial number or support the cause by purchasing the full version.
i must now ask that when you have a problem, that you first of all search the forums, or google your roblem folowed by "vdj forums", as there is an extreme amount of information covering that topic.
i wll yet again point another person th the guide i wrote on headphone setup and usage.
http://www.virtualdj.com/homepage/Blulite/blogs/4511/Headphone_Setup_and_Usage_Guide.html
Posted Tue 16 Aug 11 @ 6:05 pm
Posted Tue 16 Aug 11 @ 6:06 pm
jaschekHome userMember since 2010
Guys, can someone tell me how can u use my mic at virtual dj pro 7, coz he dont works, i try fix it at advanced config, he just make one big noise when i talk. why?
Posted Sat 03 Sep 11 @ 9:40 pm
thewerdPRO InfinityMember since 2011
Is there a way to change the function of the pitch bend buttons to instead switch between decks? I like doing a lot of 4 deck mixes but need a quicker way to switch between decks.
Posted Mon 04 Nov 13 @ 12:22 am
Hola saludos..quisiera que alguien me colabore con lo siguiente; compre una numark mixtrac pro todo funciona bien excepto que el volumen de cada canal no me baja completamente solo hasta la mitad y por eso no puedo usar los audifonos porque se ecucha la otra cancion y cuando muevo el crossfader me sube y baja ambos canales del volumen y a la vez sube y baja el pitch del lado derecho...como podria solucionar esto...MUCHAS GRACIAS
Posted Sat 18 Jan 14 @ 8:57 am
Posted Sat 18 Jan 14 @ 9:25 am
