And this persist after trying a powered USB hub, as mentionned in my previous anwser ?
DJ Phatso wrote :
El Capitan seem to be causing headaches for a lot of people, but as far as your problem goes, using a powered USB hub (meaning a hub which has a power adapter) between the DJ Console Rmx and the MacBook USB port should solve your problem and allow your Macbook to enumerate and use your DJ controller properly.
Posted Mon 23 Nov 15 @ 1:57 pm
Same problem here, Hercules RMX is not working with El Capitan, I guess it´s a driver problem
Posted Sun 10 Jan 16 @ 10:49 pm
Actually, if the controller is not detected properly to start with by OS X, the drivers will not be able to do his job.
You've tried using a powered USB hub and/or different or shorter USB cable, as mentioned previously ?
Posted Tue 12 Jan 16 @ 4:31 pm
