Forum: Mix lessons - Topic: Help with using my headphones! - Page: 1 |
| Author |
- Topic: Help with using my headphones! - |
maduza
| Posted Sat 10 May 08 @ 21:13:59 |
I want to use my headphones because itīs an important part of mixing. But it donīt work! Can someone tell me how to connect my headphones with VDJ? Maby my problem is my old-soundcard with only one connection? I need help very quick I hope someone will tell me about my problem! This are my institutions:
- Inputs: None
-Outputs: Headphones
-Soundcard(s): Mono Seperated |
TearEmUp
| Posted Sat 10 May 08 @ 21:41:59 |
This topic has been discussed many, many many times.....please utilize the search feature and you will find your answers there... |
71395
| Posted Wed 14 May 08 @ 11:11:19 |
yo dude il do the best i cn to help yu .... as u said it yoself the problem is your sound card with one output slot .... so i sujest u get yourself a new n better sound card or u cud use two sound cards with single output slots .... one for the earphones and one for sound output....adjust yo card configuration n ul be on ya way !!.. gud luck
| - Post a new Message - |
