| Author | - Topic: midi Led setup - |
Can anyone help me? I am using a Novation Twitch, with i have mapped all the buttons using a simple midi wrapper. All my button are working correctly, but i would like some help get the LED'S to work. Below is a example of what i was trying to use sampler 2 play_stop ? blink : on this does not seem to work for me. i'm not very cleaver when it comes to sorting this sort of thing, but i did give it a try. I would appreciate any help!!! |
Try: "sampler play_stop ? blink : off" "sampler 2 play ? blink" |
you need to have a definition file to map the leds, if you register another user has created a mapper and definition that you can download ![]() Novation Twitch 4 Decks 1.1 Author: mikedailor |
