hoe kan ik werken met hercules dj cntrl mp3 e2 als ik geen plek heb op m´n laptop
weten jullie mischien iets
Posted Sun 20 Feb 11 @ 1:02 pm
Please write in English only in this Forum.
Greets, Heiko
Greets, Heiko
Posted Sun 20 Feb 11 @ 1:28 pm
Hello i have one question 4 hercules dj controller..
Is it worth to buy hercules dj control mp3 e2?
There is no problem with this equipment?
please answer!
please answer!
Posted Tue 01 Mar 11 @ 2:43 pm
Hi, I bought the MP3 E2, but I've lost the disk. How can I load the LE version onto my new laptop? I bought the Basic version, mistakenly thinking I could use it with the MP3E2, and I'm stuck with a mixer I can't use!
Thanks, in advance, for your help.
Lexi
Lexi
Posted Sat 05 Mar 11 @ 1:46 pm
Please contact the manufacturer Hercules support http://ts.hercules.com - They should be able to retrieve it using the hardware serial number of the console.
NOTE: VirtualDJ Pro Basic does not support MIDI controllers. It is for mixing using your mouse and keyboard only.
This is clearly stated on the product purchase page https://virtualdj.com/products/basic.html and the product comparison page https://virtualdj.com/products/comparison.html
To use external controllers, you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/ - Or use VirtualDJ LE that originally came with the console.
Posted Sat 05 Mar 11 @ 2:11 pm
Why wont my hercules e2 work with my full virtual dj 3.4 ?! (other than mapping every single midi action...) the remote control for the hercul
es comes up red. the midi is green. please help. Thanks
Posted Sun 06 Mar 11 @ 10:26 pm
The MP3e2 will not work with v3.4 because that version is far too old. The MP3e2 console was released long after v3 was no-longer the current version of VirtualDJ. If you are referring to the eJay MixStation that is registered to your account, then this version also does not have support for any MIDI controllers and is also obsolete software - Please see https://virtualdj.com/products/djmixstation.html
If you have the full VirtualDJ Pro, please register your serial number on the page https://virtualdj.com/users/edit.html and then upgrade to the latest v7.0.2 by going to https://virtualdj.com/download/updates.html
Otherwise, assuming that your MP3e2 is not second hand and/or the discount has not already been used, please go to https://virtualdj.com/buy/ and enter your VirtualDJ DJ Console Edition serial number in the box provided to upgrade at a discount.
Alternatively, if you do not want to upgrade at this time, you can use the limited DJ Console Edition of VirtualDJ that came with the MP3e2 console.
Posted Mon 07 Mar 11 @ 4:28 am
I just bought the DJ Control MP3 e2
I know its possible to record the midi of the jogwheel, but is is it possible to midi it out to the jogwheel again? in maybe Cubase?
if yes, how?
that would be awesome because then we could edit the scratch to perfection AND save it as a midifile
if yes, how?
Posted Mon 07 Mar 11 @ 4:18 pm
Thinking of buying this for my first hardware controller but I need to know if..............
1 is it worth £80 (of Amazon)
2 Does it work with the free edition of vdj
3 I heard that Hercules give you a trial edition of vdj which works with all their controllers. is this true
4 Does virtual DJ basic work with this controller
5 Do you need a sound card for this to work
Thx
P.s I'm a complete noob at DJing ( ive been teaching my self from home with no help or lessons
Thx
Posted Wed 16 Mar 11 @ 5:31 pm
No, Home FREE does not support MIDI controllers, except for 10 minutes at a time as a trial of the full VirtualDJ Professional.
Home FREE is for non-commercial use only, using your mouse and keyboard to mix. It is not permitted to use this version at DJ gigs where you are being paid.
Hercules DJ Consoles come with a free DJ Console Edition (LE) of VirtualDJ. This is not trial software, but is limited in functionality - See: https://virtualdj.com/products/comparison.html
It can be upgraded to the full VirtualDJ Professional at a discount by going to https://virtualdj.com/buy/
No, VirtualDJ Basic and Broadcaster do not support MIDI controllers.
You will either need to use the free included VirtualDJ Console Edition or upgrade to the full VirtualDJ Professional.
Yes, if you wish to be able to headphone pre-listen to the track that you are cueing up.
You may wish to purchase MK4 instead, which includes a DJ sound card built-in with headphone pre-listening capability.
Posted Thu 17 Mar 11 @ 1:37 pm
How mutch cost an upgrade to virtual DJ Pro?
AGova_be
AGova_be
Posted Thu 30 Jun 11 @ 1:24 pm
The upgrade from MP3e2 LE to the full VirtualDJ Pro is $249
You can check/verify by going to https://virtualdj.com/buy/
Posted Thu 30 Jun 11 @ 1:37 pm
Would it be compatible with my tapco firewire as a soundcard?
Posted Wed 06 Jul 11 @ 9:40 am
There is no reason why they would not work well together, given that they are different devices (one is a controller and the other a soundcard).
If your Tapco works iin VDJ, then you are fine.
Posted Wed 06 Jul 11 @ 10:02 am
Hey guys, I have the 7.0.5 HOME free - mac,
I was just wondering if this controller would work with this version?
If not, could anyone point me in the direction of which would..
Cheers!
Cheers!
Posted Wed 12 Oct 11 @ 7:23 am
No it will not work (Except for 10 minutes at a time as the trial of the full VirtualDJ Professional.)
Home FREE supports mouse/keyboard use only. Please see https://virtualdj.com/products/comparison.html
To use MIDI controllers, you will need to purchase the full VirtualDJ Professional: https://virtualdj.com/buy/
Of if it came with VirtualDJ LE (Limited Edition) included, you can use that (And optionally upgrade to the full VirtualDJ Pro at a discount, assuming that it's not second hand.)
Posted Wed 12 Oct 11 @ 7:50 am
which midi would be okay to use with the version i own then ?
Posted Wed 12 Oct 11 @ 10:29 am
Your mouse and keyboard.
As above, Home FREE is free limited software and DOES NOT SUPPORT USING MIDI CONTROLLERS.
If you want to use a MIDI controller, then you will need to purchase the full VirtualDJ Professional or a MIDI controller that comes with VirtualDJ LE (Limited Edition) included. See https://virtualdj.com/products/hardware.html
Posted Wed 12 Oct 11 @ 10:42 am
Hi, i was wondering what software i could use if i got this with the Korg NanoPad, i mean like so i could use this and that in the same program.
And also, if the version of VDJ that ships with this does not support itunes, how do i get music?
Edit: And also with the korg microKEY, and i want to be able to sample with the nano pad,
Kind Regards,
Kevin
Please Answer! :D
Kind Regards,
Kevin
Please Answer! :D
Posted Mon 24 Oct 11 @ 10:28 am
i have the hercules mp3 e2 i bought used frm a friend are there any intro programs i can use. obv the vdj free edition is a no go. not really tryin to drop a but load on a program. i guess if there isnt any ill just amazon traktor pro. i use a windows 7 laptop. I was also wondering if i have the controller can i contact hercules and see if they can hook me up with the vdj le version? any help with these two matters will be of great help thank you
Posted Mon 04 Mar 13 @ 1:18 pm
