Forum: Old versions
Topic: how to get Led's working on "Hercules Control Air" with Virtual Dj 7 Pro
Hi,
i've been mixing with VDJ7 pro for a while now, and now i bought a Usb-Midi controller to work with my Macbook.
so I bought the Hercules Control Air, which comes with software Djuced.
I'd rather use VDJ instead, because ive been playing with that for a while now.
i almost got everything mapped for the midi controller, but one thing that doesnt work are the Led's
can i fix this in Virtual DJ?
is this a flaw in the Midi that needs to be updated, perhaps because it isnt compatible (yet) with VDJ?
what should i try?
Much Obliged
Posted Mon 16 Apr 12 @ 8:17 am
Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
Hercules Control Air is not currently natively supported by VirtualDJ: http://www.virtualdj.com/wiki/VirtualDJ%20Controllers.html
However, there is a user-made mapping for it available to download from the following page once you have purchased/registered your software: http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html
I lost my serial, as i said, ive been playing virtual dj pro for some time now, and i dont know the code.
but i already mapped the Hercules controller in Virtual Dj, with the problem of the leds not working. will the Leds work with Cioce's mapper pack? anyone have any experience with the Hercules Control Air? thanks again
In that case, please contact support to retrieve it:
http://www.virtualdj.com/contact/index.html
You will need this registered to your profile to be able to download the mapper pack.
The above mapper pack by Cioce includes a definition for the Hercules Control Air with LED's.
Thank You!
@Xnos Bonus can you send me your mappings by e-mail? I have dj control air and I don't know how to map, please I need help.
@r64doo, please do not ask users to send you plugins you are not entitled to.
To download the mapping you need to have a VirtualDJ Pro licence.
Thank you
Keith
QUERO SABER COMO FAZER PARA USAR O SENSOR DO MEU AIR CONTROL HERCULES
(WANT TO KNOW HOW TO USE MY SENSOR AIR CONTROL HERCULES)
Hercules Air is not natively supported by VirtualDJ, but there is a user created mapper for it by Coice: http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html
You will need to purchase and register the full VirtualDJ Professional to download the mapper and also be able to use MIDI controllers with VirtualDJ.
This forum is also for English language messages only.
Please post in English only or alternatively use the correct language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
