Forum: Old versions
Topic: Error in ASIO sound driver with Hercules Console RMX
I have a Hercules Console RMX and Virtual DJ 5 (DJConsole) and every time I open it, the message "Error in the ASIO sound driver" comes up. If I click OK, Virtual DJ will still come up but if I try to play music, the play button will turn blue like normal but the music doesn't play. I changed the playback device to my computer's internal sound card like it said under the FAQ and tried changing the audio mode under the control panel for the Hercules RMX to ASIO but it switched back to WDM and gave me the same error message when I opened VDJ again. I have Windows XP, Virtual DJ (DJC) and Hercules Console RMX, someone please help me!
Posted Fri 30 Dec 11 @ 9:10 pm
hey that hapening with my hercules 4 mx its the same message id tried fix but still same i need help too...
Ok so I downloaded the firmware and when I looked at the instructions in that link you added, it said to click on "more" in DJC to change the settings but when I clicked on it, the only thing that came up was the box asking if I wanted to upgrade to pro. Is there some other way to change the options?
VirtualDJ LE is limited software, so I don't think this is possible outside of the 20 day trial.
If you can't access the sound setup, then download and install Home FREE: http://www.virtualdj.com/download/free.html
Run it with the console connected and verify that the settings are set exactly as on the pages above. Then close it before the 10 minute Pro trial is up and go back into LE.
i have done all of this i still get this problem
I would suggest uninstalling all Virtual DJ:
- From the first window of the installer, select CUSTOM
- for every subsequent windows, choose SELECT ALL for every following ones
This will insure that all fines related to the software are removed ( the folder Virtual DJ should not be present in Document once the uninstallation is complete).
Then reinstall using the latest LE version (5.2.2) only.
I followed all but the message is still further..
