I notice that for "rip vinyl", there is the possibility to precise the kind of input : microphone, phono, kine ....
So, I think it would be interesting to have the same possibility for the output of the sound card.
I mean when you use VDJ with a mixtable (table de mixage in french), there is a lot of inputs you can not use because you can use only the Line input. But in no case, you can use Microphone input and phono input of mixtable.
As we can choice the kind of inputs without a special sound card because rip vinyl can do it, I think VDJ could transform an output of sound card: line, phono or microphone(for example in advanced config)Thus, we can use every input of mixtable.
It will be usefull to listen samples separetely before launching them, and manage the sound level of each sample with mixtable.
I hope you can understand what I mean. It is not very easy for me to speak in english
Denis
Denis
Posted Sat 18 Dec 04 @ 9:53 am
