Forum: Old versions
Topic: will creative Sound Blaster Audigy 2 ZS Platinum Pro work for tcv
if i get a creative Sound Blaster Audigy 2 ZS Platinum Pro will it work for tcv?
you know connecting 2 turntables with the timcode vinyl to mixer and then the
creative Sound Blaster Audigy 2 ZS Platinum Pro sound card to work with virtual dj?
Posted Sat 16 Feb 08 @ 8:02 pm
I don't believe that card has 4 inputs and 4 outputs which is what you need for TCV Setup.
Actually it works pretty well with tcvs you only need to work with registry asio inputs, front pannel are the inputs and rear pannel for outputs, I used it long time ago.
heres what dj-in-norway said in another fourm
There are plenty of good asio soundcards, depending on what connection you wanna use
USB card that work good :
- Maya44 usb
- U46DJ
- Edirol UA-1000
- Hercules (bit slow for superfast scratch)
and more
Firewire cards that work good:
- Prosonious Firebox
- Shaffire Le
- Edirol FA-66 , FA-101 and more
- Digidesign Digi 002 Rack
- Ego-Sys QuataFire 610
- Hercules 16/12 FW
- M-Audio FireWire 1814
- Terratec Phase 88 Rack FW
and more
PCI cards that works good :
- Delta 44 & 66, Delta 1010LT & 1010
- Soundblater X-FI platinum or elite
- Mayy 44 PCI
- Maya 1010
- Sound Blaster Audigy 2 ZS Platinium Pro
- Sound Blaster Audigy 4 Pro
- Echo Layla 3G
- Ego-Sys ESP1010
- Ego-Sys WaveTerminal 192M
- Soundblaster E-MU 1820, 1820M
- Marian Marc 4 MIDI
and lots more
PCMCIA cards that works good
- Soundblaster E-MU 1616M
- RME Audio Hammerfall DSP System
Generally speaking, almost any card that has two line ins in STEREO, and two line outs, will work, and has ASIO drivers its likely to work (with low latency drivers).
Those listed above are PRO cards, so some are damn expensive..
But get a card thats not the most expensive, but not the cheapest eather.
Soundblaster offers some good solutions for value.
have a audigy 2 plat pro and was trying to get it working, go tone , other deck had problems. no on one the forum wanted to help so i'm stuck..but if they say it works i guess it does..it's just a pain the asss.
you need to tweak virtual dj Registry settings to map the correct input to output on soundcards. Its not hard to do, and all sound cards are different.
