Please help
I have just purchased all of the above kit but after installing everything and trying to run VDJ the error message:
'the controller has not been detected' comes up.
I have tried installing the Trial Version of VDJ which does seem to work although i can only get everything running through the one channel.
Has anyone got a solution fo that i can get my version of VDJ working, I have tried it all on an older pc running Windows XP Home SP2 and everything is fine.
Cheers
Cheers
Posted Sun 16 Dec 07 @ 6:54 am
normally the trial version has the option to use an external mixer locked. It is only unlocked once you've purchased the software, are you sure your not using a cracked version?
Best Regards
DJ White Devil
Best Regards
DJ White Devil
Posted Sun 16 Dec 07 @ 7:43 am
Thanks for coming back to me, the version I have bought is an original, which works on XP but doesnt see the controller when installed on Vista. The trial version downloaded from this site works on Vista with the mixer.
Obviously, what I am trying to acheive is to get my purchased version of VDJ Limited working on Vista.
Any suggestions gratefully received!
Posted Sun 16 Dec 07 @ 9:22 am
Please enter your serial number here in the forums for the one you bought
Posted Sun 16 Dec 07 @ 5:22 pm
I cant seem to get my virtual dj limited running on my vista i have an ion imx02 mixer and have the cd with it desktop dj software version 1.3 but the same thing comes up THE CONTROLER HAS NOT BEEN DETECTED. please help
Posted Tue 21 Oct 08 @ 10:54 am
I have similar problem, bought the Ion iCJ01 mixer and vdj limited will not run, just get message "controler has not been detected". I downloaded the trial version which works fine but only for 20 days. I Tried on 3 PCs with Vista and XP but keep getting the same message! Any help much appreciated.
Posted Thu 04 Dec 08 @ 9:15 am
and there isnt even a technical support help line shocking
Posted Wed 31 Dec 08 @ 3:33 pm
Good Morning,
Tech support is available for the mixer, there is a slip in in all ION products with the contact details.
The lines will reopen at 9AM tomorrow.
Virtual DJ limited edition is a free software version provided by Atomix , it is not possible to register it online.
It does not support windows Vista.
It does however fully support XP, please ensure all USB cables are connected to your computer as the software will not run if the mixer is not detected.
There are many free alternative products you may wish to try.
Currently this mixer is stocked in Maplins in the UK for 39 pounds/ 56 dolars which is very good value.
The price of the package included the Mixer, headphones and a Microphone the software was included as a complimentary taster of Virtual DJ.
It is a very high quality Usb Mixer (previously valued at 120£) and can be used with any software product including the full version of Virtual DJ.
Should you have any issues setting up the mixer on XP or with other software please contact Ion Support:
US:
200 Scenic View Drive
Suite 201
Cumberland, RI 02864
United States
Tel: 401.658.3743 HQ
support@ion-audio.com
UNITED KINGDOM
Unit 9, The Christy Estate
Ivy Road
Aldershot Gu124TX
United Kingdom
Tel: +44 1252 341400
uk-support@ion-audio.com
GERMANY
Halskestr. 16-18
47877 Willich Germany
Tel: +49 2154 8143 0
Kind Regards
Simon Bangs
Computer DJ specialist.
Ion Audio / Numark Industries
US:
Suite 201
United States
UNITED KINGDOM
Ivy Road
Aldershot Gu124TX
United Kingdom
GERMANY
Halskestr. 16-18
Kind Regards
Simon Bangs
Posted Thu 01 Jan 09 @ 5:53 am
