Im having serious problems with having my samples slightly out of phase/sync with the currently playing song. This is even with the cgbs/bpms set as right as i can see.
Anyone else? Any tips?
Posted Mon 02 Aug 04 @ 10:02 pm
was the cbg also aligned under beats when u made the samples? have had a bit of out of sync problem when not having adjusted this when i made the sample
think this is because the beatlock engine uses the cbg to make them sync
Posted Mon 02 Aug 04 @ 10:05 pm
only trick is, i dont trust the beatlock engine (no offense devs.)
Posted Tue 03 Aug 04 @ 1:28 am
well... i dont use the beatlock engine too.. for other reasons than not trusting it ;)
BUT, there is no way to nudge the samples, to speed them up/down.. so when it comes to samples, u gotta use the beatlock engine (built into samples, if turned on).
so - in this case, cbg alignment on beats is essential when MAKING the sample.
Of coruse u dont have to have the song you are playing in beatlock when using the sample, but the sample itself "sticks" to the song u are playing using the beatlock engine..
if u see what i mean :)
Posted Tue 03 Aug 04 @ 1:40 am
Maybe check also the synch and beatlock options close to gain samples sliders.
Posted Tue 03 Aug 04 @ 6:16 am
Maybe in the next update they can place a speed bar next to the volume bar for manual use?
Posted Wed 04 Aug 04 @ 3:50 am
