Topic: BCD2000(Behringer controller DJ) compatibility issues with Inspiron 5100
dydy1PRO InfinityMember since 2006
BCD2000(Behringer controller DJ) compatibility issues with Inspiron 5100. I ran into problems with ressource issues when I install the BCD200 driver to work with the inspiron 5100. under system info in the laptop. It says that IRQ11 is where my wireless card,my mobility raedon 7500c,texas instrument pci card are. Using the BCD200 with the laptop is a problem, because after two minutes. I get no sound, and the reason is too many drivers is connected under the same ressource which is IRQ11. Does anyone has a solution to this problem??
Posted Tue 10 Oct 06 @ 11:48 pm
phillydjPRO InfinityModeratorMember since 2004
Have you tried a diffrent Usb port? or uninstall ur usb ports, wireless card and video card from the hardware managment and hopefully they will get reinstalled with diffrent IRQ's
If you can get into your bios theres also a way to clear the pnp irq's there
Posted Tue 10 Oct 06 @ 11:51 pm
I uninstall the wirelless card which seems to be using most of the ressources. when I reinstall the wirelesss driver it went back to the same area it was previously installed(IRQ 11). Is there anyway to relocate the wirelless driver manually??
Posted Wed 11 Oct 06 @ 12:53 am
