i m actually looking for visual stem separation in RGB color waveform. how can i make the stem separation color waveform look like Serato dj pro? the stem waveform display in Virtual dj only show in shapes. bass stem and hi-hat stem didn't show any visual shapes waveform. vocal stem waveform didn't show bright color shapes even tho the vocal is clear and loud to listen. the vocal stem waveform didn't show shapes waveform as bright as drum and kick stem.
Posted Wed 01 Jan 25 @ 3:38 pm
Not sure why no one else has responded to this.
Option settings, click options. In the search box at the top of the window type in the word waveform
Then, set both skinWaveformType & skinOverviewType to colors
That simple :)
(note, on VDJ v2025 b8502 changing skinOverviewType doesn't seem to work, you have to set it's value first, then change skinWaveformType which causes both to update to what's picked)
That simple :)
Posted Fri 31 Jan 25 @ 3:59 pm
