Topic: Auto swap beatlock between decks in one click
Hello DJ's
I have two Denon LC6000s that I use with VDJ
I remapped the Sync button on each LC6000 to the Beatlock function which suits my workflow very well.
However, I would like that when I push the button on the LC6000 which controls Deck 1 it enable beatlock on the deck 1 and automatically disable beatlock on Deck 2 and vice versa if I push the button to enable beatlock on the LC6000 which controls Deck 2 it automatically disable beatlock on Deck 1.
Currently I have to remember to manually deactivate one side when I activate the other, which takes an additional manual step and disrupts my workflow.
Does anyone know the script to be able to perform this action?
Posted Wed 24 Apr 24 @ 2:42 pm
