I spent a good couple of hours last night creating folder and playlists on a CDJ Export USB stick.
Just went to add a few more tracks and the drive isn't recognised.
I can view the drive in explorer and I can see there's ~30Gb of the drive used.
But VDJ doesn't see it.
Any ideas?
Roy
Any ideas?
Roy
Posted Fri 04 Feb 22 @ 2:18 pm
More information to try and explain my issue:
The file is formated exFAT - not NTFS
When I plug the thumb drive in, it shows up in CDJ Export. This drive is not empty, there are lots of folders and playlists that I have previously exported, but there is nothing for me to navigate.
So I try and create a folder that I know already exists.
And as expected, I'm told the folder exists, but I cannot see it and therefore navigate to it.
I also still get the message:
Would you like a copy of the PIONEER folder on the drive?
Posted Sat 05 Feb 22 @ 7:41 pm
exFat is not the same as fat32
just a fyi :-)
just a fyi :-)
Posted Sat 05 Feb 22 @ 10:52 pm
Yeah... Had that realisation about 10muns after I posted...
Posted Sat 05 Feb 22 @ 11:38 pm
