Since one of the latest updates (somewhere before Xmas 2020) I cannot drag and drop tracks into decks, into the sidelist etc. previously, it worked fine! I checked with both my touchpad (macbook pro) and a mouse attached. the touchpad/mouse basically works: i can press all the buttons, move sliders etc. Just the dragging and dropping doesn't work anymore. I find that really strange and I cannot think of this being implemented deliberately. So I strongly assume that it's a bug.
I also thought of MacOS Catalina prohibiting to Virtual DJ access to the mouse/touchpad (security settings) - but that also seems not to be the case, because why would all the other actions work?
I updated right now to the latest version (8.5 b6294), but the problem persists.
Anyone any idea of what that could be? Thanks!
MacBook Pro Mid 2015
2,8 GHz Quad-Core Intel Core i7
MacOs Catalina 10.15.7
Posted Mon 08 Feb 21 @ 12:09 pm
Maybe you have the touchscreenMode enabled in options?
Posted Mon 08 Feb 21 @ 1:20 pm
I just checked: no, I haven't.
Posted Mon 08 Feb 21 @ 2:26 pm
but I did "reset all" in settings, and now it works again. Some settings look different now (need to check in detail) but at least dragging works again. thanks for your suggestion!
Posted Mon 08 Feb 21 @ 2:30 pm
