Hi there, does anyone know when the issues with VDJ will be fixed in relation to Big Sur on Macbook ?
Posted Wed 06 Jan 21 @ 4:47 am
The latest version of Virtual DJ is supposed to work properly with Big Sur. Make sure you have the newest version.
Posted Thu 07 Jan 21 @ 4:31 pm
What issues do you think Virtual DJ has operating on Big Sur?
The main issue with Big Sur is Pioneer (among others) haven't updated their drivers to support it. Therefore whilst Virtual DJ works - you need to check whether your hardware is supported or not.
Posted Thu 07 Jan 21 @ 7:49 pm
I've been using VDJ on Big Sur since it's release with no problems, although I use Denon Controllers MC7000 & MC6000 Mk2.
System Specs;
MacBook Pro 15” 2017 (Touch Bar), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3 Memory, Radeon Pro 560 4096 MB, Intel HD Graphics 630 n1536 MB, macOS Big Sur 11.1, 500gb SSD Bootcamped with Windows 10 x64bit. External WD Passport Ultra 2Tb HD containing Music & Video databases and is formatted NTFS, I use the Paragon plugin with NTFS for Mac.
VirtualDJ 2021 b6242 and Controllers - Denon MC7000, Denon MC6000 MkII.
System Specs;
Posted Fri 08 Jan 21 @ 1:53 am
