Hi team,
Im running a Mac with a Pioneer WeGo2 with Virtual DJ 8 and using iShowU audio capture to feed it into OBS. Everything works and OBS can pick up the audio coming from Virtual DJ. I am not using any external soundcards or mixers, the MIDI controller is plugged into the Mac. When I plug my headphones into the WeGo to Cue songs etc I dont get an audio feed... when i disconnect OBS and iShowu and just use the WeGo with Virtual DJ on my Mac it all works fine. What am I doing wrong here?
Thank you all!
Thank you all!
Posted Sat 18 Apr 20 @ 11:31 am
I don't quite understand the need for the additional software. VDJ can broadcast on its own.
You say you're not using an external soundcard, but the WeGo2 is an "external soundcard". If you're plugging your headphones into it then you're using it. :-)
We need to see your VDJ audio config, but I suspect if you haven't got the WeGo selected as default I/O then that's why you're not getting a cue signal.
Posted Sat 18 Apr 20 @ 1:20 pm
