A lot of my songs are messed up. Sometimes it is just the vocals sounding too deep or too high, and sometimes I get the chipmunks singing.I have rolled back to Vdj 8. I have changed the PitchLock to 'NO' from yes, and now the first time I put a bad song on, it's bad, but the second try it is correct. Most songs are staying 'correct' but a few are stubborn. I have a lot of music and I cannot possibly go through ever single file. Prelisten does not indicate any problems, so that is not helping me. 1. Is there a way to reset my entire collection? 2. Is there a way to know before I play a request if that song will be correct or not? Thank you in advance if anyone can help me.
Posted Tue 21 Jan 20 @ 2:21 am
You should probably simply install VDJ2020 again (install on top), and then disable the auto settings like in the video below
Also make sure that your MasterTempo is set to yes, so you won't get chipmunks if you choose to click sync or use the pitch faders
Posted Tue 21 Jan 20 @ 1:12 pm
