Topic: VDJ 2020 - Telemedia Visuals not showing up in video effects window anymore
Since upgrading to VDJ 2020, my Telemedia Visuals is not showing up in the video effects window anymore. I see the Telemedia plugin is still in my C:documents/virtualdj/plugins folder. Any ideas?
Posted Thu 26 Sep 19 @ 10:02 pm
VirtualDJ 2020 default installation is 64 bits.
So it can use only 64 bit plug-ins.
You should either ask if TellyMedia has a 64 bit version, or download the 32 bit installer and install 32 bit version
Ahhhh gotcha! No problem. I'll just go back to the 32 bit version for now. Got an important video DJ gig tonight. Thanks so much for the fast answer!!!
There is a beta 64bit version, go to Don's site.
Yep I saw that. It costs $40. I sent him the $$$. Now I'm waiting on the license code for it to work. I'll use the 32 bit VDJ 2020 until he sends me the code.
Legit, I assume you have the license code? I was in the process of redoing the license code procedure for all versions and is why I have not activated you for the beta 4 versions yet. This should be done within an hour...
If you have not received your code, than please email me... I can't identify you from your name here and the names I receive via donations.
donmoir@comcast.net
Once I know who you are for sure, I will add your DJay 2Legit name to the records I keep..
Legit, you should be good to go with the 64 bit Betas TV 4.23 and TM 4.06. Also any others that may have made recent donations. I had to reorganize everything and if you find any problems let me know.
Yes, it's all good to go now Don. Thanks so much for getting me the license code and updating the software. Everything is working like a charm now.
