After I updated the VDJ to 5186 build (PC version) and use the VDJSpoutSender plug-in to send video to other app,
I found that the video resolution would be very low while I use the "Preview only" on the VDJ.
In previous build 5046 everything was fine.
Any suggestions?
Any suggestions?
Posted Fri 16 Aug 19 @ 8:45 am
You're right, Spout sender is using exclusively Video from Master. It seems it gets the size after the final renderer which is size of preview when in preview only mode.
If you were using a 4K display this would have been the opposite, Too big video and heavy load for network
As a workaround for Spout, you can make the unused video windowed NOT fullscreen NOT always on top under the main VDJ window
Posted Fri 16 Aug 19 @ 9:38 pm
It's a change made in VDJ that now gives the preview window image size to a plugin. Spout has nothing to do with it. Previously they gave the size of the display window even if not visible to a plugin when in preview mode.
Posted Sat 17 Aug 19 @ 6:18 am
I think that's the point! VDJ may change something in the window image size because I use the same Spout plug-in.
Thanks god I found this issue before the live show. I think I should turn off the VDJ auto update now.
Posted Mon 19 Aug 19 @ 9:50 am
As soon as an extra video panel showing Master is open once VDJ definitively send the full size ^^
Posted Mon 19 Aug 19 @ 11:24 am
It is about when in preview mode with no video panel open. And if video is showing, it is the size of the video window so making it very small could show same thing but not likely you do that.
Yeah they change things on a wim kind of like the surprise of the week. With the updates I used to say: "Your dammed if you do, and dammed if you don't"
Posted Mon 19 Aug 19 @ 11:15 pm
the new spout plugin for VDJ - THANKS TO groovindj
https://github.com/leadedge/SpoutVDJ
https://es.virtualdj.com/forums/198486/VirtualDJ_Plugins/Spout_for_Virtual_DJ.html?page=3
and the new future VDJ SDK entries - THANKS TO Adion
http://es.virtualdj.com/forums/227449/Video_Discussion/VDJ_2018_Syphon___.html
both combined seems to give what is needed:
- input resolution in preview onlymode
- image send with video skin aplyed
I compiled a test version and post a test result in the hope of something officialy working and well implemented will come
virtual dj spout resolume in spout forum
https://spout.zeal.co/forums/topic/virtual-dj-spout-resolume/page/2/
Posted Thu 02 Jan 20 @ 12:04 am
By the way in addition to previous:
- fixed Enable/disable not working
- added Per deck sender; allow multiple track to multiple senders
- Recording resolution as default
i.e.: Left deck + Master deck with video skin + Right deck each in a different receiver
http://imgshare.free.fr/uploads/54ddfdbe15.png
.... strangely resulting FPS seems 10*3 faster the VDJ internal Renderer
Posted Thu 02 Jan 20 @ 4:55 pm
