anyone else had this problem, the drop down transitions menu is showing audio effects only, searched forums for possible answers, transition folder etc is where it should be and has not been changed for years using vdj 8.3 build 4845,this is getting frustrating so any clues gratefully recieved
Posted Sun 14 Apr 19 @ 4:40 pm
You can check settings.xml in your Documents\VirtualDJ folder and look for videoTransition.
Sounds like it might be set to an audio effect somehow. You can remove the line to reset it.
Posted Sun 14 Apr 19 @ 4:49 pm
Tried that adion and restarted vdj made no difference, its also defaulting to cross fader curves audio effect
Posted Sun 14 Apr 19 @ 5:10 pm
You edited it with virtualdj not running right?
Posted Sun 14 Apr 19 @ 5:28 pm
by editing do i delete the whole or part of the line, editing xml files is not something i`m familiar with, i normally leave well alone
Posted Sun 14 Apr 19 @ 5:40 pm
Perhaps safest to change it to <videoTransition>Satellite</videoTransition>
Posted Sun 14 Apr 19 @ 5:44 pm
did that with vdj not running and saved file but made no difference,maybe i should repost on tech forum
thanks anyway adion
thanks anyway adion
Posted Sun 14 Apr 19 @ 5:57 pm
Some skin or script might be resetting it to 'cross fader curves' then.
Perhaps try to rename the settings.xml to start with a clean setup and see if it still happens then.
Posted Sun 14 Apr 19 @ 6:05 pm
you`re a genius Adion worked like a dream, many thanks
Posted Sun 14 Apr 19 @ 6:26 pm
All my videos transition are gone after I'm upgrade to V8.3 b4918, I already back to a older version, and still no working.
Thanks
Thanks
Posted Fri 10 May 19 @ 4:16 am
Just restore everything from one of the the backups that you regularly make.
You do make backups?
Posted Fri 10 May 19 @ 4:59 pm
It might be some corruption in your settings.xml (videoTransition item set to a non-transition effect)
Posted Fri 10 May 19 @ 5:01 pm
How do you do that?
Posted Sat 11 May 19 @ 3:19 am
Where I Can check that?
Posted Sat 11 May 19 @ 3:21 am
I already check my setting xml, and this is what show: videoTransition>Screen Grab</videoTransition>
How do you change this?
Posted Sat 11 May 19 @ 3:25 am
Close vdj, remove that line from settings.xml, then restart vdj
Posted Sat 11 May 19 @ 3:51 am
![](/img/290816/36890/vdj.jpg)
This is what show on my screen
Wherever I do, won't change
Show Screen grap on both side
I open Virtual DJ 7, no problem
Posted Sat 11 May 19 @ 4:18 am
you removed screen grab from settings.xml ?
Posted Sat 11 May 19 @ 5:07 am
I don't know how to do it?
Posted Sat 11 May 19 @ 5:24 am
setting xml, videoTransition>Screen Grab</videoTransition>
Close vdj, remove that line from settings.xml, save, then restart vdj
failing that try the same with videoAudioOnlyVisualisation, just a punt
Posted Sat 11 May 19 @ 5:46 am
