Hi I am using virtual dj pro 8 and need help with playing hot cues. What I am trying to do is play 2 hot cues at the same time with out the sound changing to a single hot cue. I want to press hot cue 1 and play a beat continuously then press hot cue 2 for a beat in the background.
It seems like I can only play one hot cue at a time, the first hot cue stops right when I press the second hot cue. I want both hot cues to be able to play simultaneously. It would also be great to play more then 2 hot cues simultaneously because I have 4 hot cues on my dj controller. Does anyone know the hot cues settings?.
Posted Thu 04 Oct 18 @ 6:17 pm
Hot cues are not meant to be used like that. That's why they don't work the way you're trying, nor they can switch to such a "mode"
The best alternative option is to load the same track on more than one deck, or use the sampler.
Posted Thu 04 Oct 18 @ 6:44 pm
