Topic: No USB Sound Card for MOTU MicroBook II
Hi, I have a MOTU MicroBook II sound card, and I can't see the option for USB sound card in audio settings.
I can select MicroBook ASIO for output but when I select them for Speaker + Headphone, Virtual DJ only make them as Stereo to Mono Splitter, no USB sound card option available.
How can I enable USB sound card option for my MicroBook II?
Posted Wed 18 Oct 17 @ 1:19 am
Manually create a line in your Audio setup like..
Master .... MOTU ASIO ... Chans 1,2
When the MOTU ASIO is selected, what Channels Options do you get in the next drop-down ?
If only Chans 1,2 is offered then something is wrong with the driver reporting less channels or drivers not installed properly ?
If you get more options like Channels 3,4 etc... then create a 2nd line like ..
Headphones ... MOTU ASIO .. Chans 3,4
Screenshots would help if the above doesnt help.
