I have my live broadcast set up and streaming on my Icecast server. All is well.
Im using a Presonus AudioBox 96 USB external soundcard.
I have audio setup as follows:
Output: Speaker Only
Card: Internal Soundcard
Input: Microphone
Under outputs:
Master: AudioBox USB 96 (WASP): Chan 1&2
Inputs: mic: Yeti Stereo Microphone (WASAPI) chan 1 & 2
I have two powered monitor speakers coming out of the main outputs on the usb card.
Its all working except when I use my Yeti it has terrible feedback in the speakers (loud hum). I want to be able to here mic through the speakers and also output to the internet broadcast since I stream live in a local micro brewery.
Hope this helps explains what I have. Any help on the mic issue will be greatly appreciated.
Input: Microphone
Under outputs:
Posted Wed 02 Aug 17 @ 6:09 pm
if the mic picks up your speakers you will have feedback. Position the mic so it doesn't have a speaker pointing at it.
maybe this info will help you out http://www.wikihow.com/Prevent-Microphone-Feedback
Posted Wed 02 Aug 17 @ 10:15 pm
I've just looked up the Yeti mic (thanks Google) and see it has four selectable pickup patterns.
Make sure it's on Cardioid mode - not stereo, omni or bi-directional. Then it will mainly pick up sound from the front instead of all around.
Posted Wed 02 Aug 17 @ 10:27 pm
