Hi,
Ive just setup my F11 key for music fade for using mic over the music. Thing is when I press to talk it dips my music too fast? is there a away to make it smoother, slower to fade?? Tried looking in the forum for help on this but not found anything. Ive been given the following link by locodog
http://www.virtualdj.com/user/locodog/blogs/5249/2_Dial__1_Button_Ducking_with_the_Volume_FX.html
Ive installed it but cant find the installed plugin? I am now completly lost on how to set this all up. Can anyone help me please???
Thanks in advance
Mike
Thanks in advance
Mike
Posted Wed 04 May 16 @ 12:28 pm
the effect is called the volume effect, you don't really need to see it,
the blog tells you to set two custom dials within vdj, [to set bottom level and duke rate] and set a custom button, which if you call your custom button with whatever else vdj script you have on f11 will give you controllable software lead mic ducking
Posted Wed 04 May 16 @ 8:20 pm
