Hey there,
if the crossfader of my Numark Total Control is completely moved to the left I still hear the right deck a bit. When I´m moving the mouse above the crossfader I see that it is on 1,72%. I can fix that if I move the fader completely to the left with the mouse. But it do not work with the fader of the Total Control :(
Tonight I am on the decks on a party and I dont wont to mix like that.
Posted Sat 09 Nov 13 @ 12:01 am
I've been partying a bit, but try mapping it again. Go to the mapper delete crossfader, hit green plus. Then hit key learn move crossfader, then hit action button click crossfader with mouse. Seems like vdj is seeing it wrong. Could also be fixed with a restart. Does the unit except firmware updates? Might need a reset if so. Try to install or reinstall the latest firmware. This should reset the controller.
Posted Sat 09 Nov 13 @ 1:08 am
you could try something like this to avoid the edges doing anything, then get some duct tape with something that has a hard edge under it to restrict the movement of the crossfader... or just use the volume faders.
param_smaller 3% ? nothing : param_greater 97% ? nothing : param_multiply 104% & param_add 2% & crossfader
Posted Sat 09 Nov 13 @ 1:23 am
This could be a hardware fault with the crossfader in the Total Control, or it may just need cleaning.
Please see http://www.virtualdj.com/wiki/Button%20on%20MIDI%20controller%20does%20not%20always%20respond.html
Posted Sun 10 Nov 13 @ 11:58 am
Probably just dirt/dust.. as said.. Clean the controller and it should be fine ;)
Posted Mon 11 Nov 13 @ 10:09 am
