Forum: Old versions
Topic: Virtual DJ Pro 7.04 on Macbook Pro controlling Pioneer XDJ-R1
Greetings.
I am having problems trying to control my recently bought Pioneer XDJ-R1 system with my Macbook.
I used to save my mixes and sets when I had my numarks, but now I dont see a way to even control this device.
The mixer mode on the XDJ-R1 is set to PC but still I cant do anything with it.
Is there going to be an update or something for this?
Posted Mon 30 Sep 13 @ 1:22 pm
Thanks for the help.
Let me understand you correctly.
So, I cant use other versions of VirtualDJ but only the LE version?
Home Free, Broadcaster and Basic versions of VirtualDJ do not support midi controllers.
That leaves the LE versions and Pro Full.
Your controller came with a free Le version of VirtualDJ. If you wish to have more features, you can upgrade to Pro Full at a discount
Thank you DJDad, dully noted.
Now, can you ensure me that the upgraded version for Mac will work with the XDJ-R1?
If you use the actual Pro Full from our side and a special mapper, also from our side!
Yes :-)
Yes :-)
Thank you Haui70.
i didnt know one could get special mappers from your side.... good to know
How to set up my new macbook pro with cdj-400 or xdj-r1
Need it now... Thanx!
djdad wrote :
Please follow the proper setup .. http://www.virtualdj.com/wiki/XDJ-R1.html
and regarding the CDJs, please have a look here:
http://www.virtualdj.com/wiki/CDJ-400.html
PS: Do not 'hijack' a topic by posting a message or question that is not related to the topic in any way. If you wish to post an unrelated message, please open your own new topic in the appropriate forum (Click on the pen and paper icon at the top of the forum topic list.)
The XDJ-R1 is supported by our latest Pro Full which is available from your download center!
The 7.0.4 does not support the XDJ-R1 out the box.
So please use always the latest version from your downlooad center!
closed
