Topic: numark mixtrack 2 and virtual dj yes or no?
ive just downloaded virtual dj for my mac a week ago. up until then i have never used any dj software or any decks or anything, im getting really into it im thinking of buying a controller, for my bedroom, the numark mixtrack pro 2 because its affordable and for beginners. ive just realized vdj doesnt come with it, can it be set up with it some how?? would the mixtrack pro 2 work with virtual dj free? im into house music edm is virtual dj and mixtrack pro 2 the way to go? or shud i get different software or controller?
Posted Fri 29 Mar 13 @ 4:42 pm
I have VDJ Pro Basic. I want to start using a compatible mixer. I was looking at the Numark Mixtrack 2. Will it work?
No it will not work. VirtualDJ Basic is for keyboard and mouse only as clearly stated on its product page and does not support using MIDI controllers.
You will need to upgrade to the full VirtualDJ Professional to be able to use MIDI controllers and much, much more: http://www.virtualdj.com/buy/index.html
Please see comparison.
I just upgraded from VD LE to VD PRO 7 and my mixtrack 2 controller won't work plz help
The first thing you need to do is register you're Pro serial number. http://www.virtualdj.com/users/edit.html
As above, please register your Pro serial number to your account http://www.virtualdj.com/users/edit.html and then download the latest v7.4 version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.) Your VirtualDJ LE entitles you to a discount off the cost of upgrading.
