Forum: Old versions
Topic: having problem with my numark dj io and virtual dj le
this is my first post just got my 1st usb controller and im having issues getting it set up i bought a gemini ctrl one came with vdj le + numark dj/io 1st day i used the controller and virtual dj i didnt use the sound card everything work fine off course couldnt use the cue cause didnt have the sound card nxt day installed the sound card everything seems fine go to the settings input none believe output headphones and asio driver here is where my problems starts at first i got static in my headphones and no sounds out of my speakers then the static went away but still didnt have sounds the other thing that was going on is that i load a song and i press play and it plays but its really but really slow(still not sound) but if i go back to the settings with out the sound card everything goes back to normal and i can play and mix with no problem
Posted Fri 03 Jun 11 @ 12:22 pm
First, please ensure that you have the most recent version of VirtualDJ LE installed. Register your LE serial number on the page http://www.virtualdj.com/users/edit.html and then go to http://www.virtualdj.com/download/updates.html to download it.
Next, make sure that you have the latest Numark DJIO drivers installed from http://www.numark.com/djio
Go to CONFIG -> Sound Setup and choose the following:
Inputs : None
Outputs : Headphones
Sound card : ASIO (Choose Numark USB in the drop-down list.) (Mac: 4.1 card -> Numark)
Choose Channels 1/2 main 3/4 headphones.
Click APPLY.
Plug a pair of amplified stereo speakers into OUTPUT 1 on the back of the DJIO and your headphones into the headphone socket of the DJIO.
If you still get sound break-up and/or stuttering, then you may have performance issues with your computer. Please see http://www.virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html for a list of common causes and their solutions.
i do have the latest drivers for the djio, iill have to see if my vdj is the latest version and i just bought 2 extra gigs of ram for my latop and hope that will fix it appreciate the help thank you!!
