i just bought a numark mix deck with vd7 and ive done all the updates for both the mixdeck and vd7 but everytime i use vd7 after about 2-3 minutes it just freezes. sometimes when i put it in midi mode the vd7 doesnt recognize or acknowledge that its in that mode... the equipment is brand new and its driving me crazy, not to mention tech support is only mon-friday ????? ive spent all weekend trying to figure it out... i also disabled all start up programs because i read someonelses promblem ... didnt work
my computer is an hp pavillion entertainment pc which is new also.... someone please help me fix the freezing
Posted Sun 10 Apr 11 @ 6:47 pm
i would really really appreciate if anyone could help me out
Posted Sun 10 Apr 11 @ 6:56 pm
What are your settings?? Post those and we'll start from there.
Huey
Huey
Posted Sun 10 Apr 11 @ 8:17 pm
what settings are you referring to???? im kinda new at this ..... be more specific if you could please
Posted Sun 10 Apr 11 @ 10:05 pm
Ok look up top on the skin and look for a button that says "CONFIG", click on that and a window should open up. In here is where you can tweak VDJ. Look for a tab that says "SOUND SETUP", now take a screen shot or tell me what you have there. It should read,
INPUTS=NONE
OUTPUT=EXTERNAL MIXER
SOUNDCARD=ASIO, next to that there is a drop down choose "MIXDECK", now below that there's a check box that says "ULTRA LOW LATENCY", make sure that box is checked. Click apply then ok and try it out.
Let me know
Huey
INPUTS=NONE
Let me know
Huey
Posted Sun 10 Apr 11 @ 11:01 pm
hey i did those changes ... had it going for maybe 8 mins and then i minimized it and tried to open frostwire to download music..... as soon as i did that i believe is when it froze up again.... help please!!!
Posted Sun 10 Apr 11 @ 11:53 pm
it does nothing when it freezes . the music just stops and you cant do or hear anything.... is there a specific method to starting up the program like when to turn on the mixdeck and put it in usb midi mode? do you have to make sure nothing else is going on in the computer .. like other programs and stuff??? it seems as if its so sensative i dont understand
Posted Sun 10 Apr 11 @ 11:58 pm
hello can anyone help mE??????
Posted Mon 11 Apr 11 @ 12:24 am
Yeah sounds like your tryin to do to much at once, why are you tryin to download while playing VDJ anyways?? Shut down everything that you possibly can. Sounds like your system is a little weak, what is it? Post you computers specs. Bro its like 1am where I'm at so relax, your not always gonna get an immediate response back, lol!
Post your specs
Huey
Post your specs
Huey
Posted Mon 11 Apr 11 @ 1:06 am
One thing to check, make sure you are running a skin that is matched to your displays native resolution! Make sure you arent running VDJ maximized to fit a larger resolution. I have had the same issues if it was running on the wrong resolution and I tried to minimize to do other things. Let us know what resolution you are running as that is a start.
Posted Mon 11 Apr 11 @ 5:17 am
You should purchase your music from legitimate sites rather than downloading it illegally. Or subscribe to Premium Membership: http://www.virtualdj.com/products/membership.html
Illegal music and other downloads are a good way to infect your system with viruses, spyware and other malware. P2P applications can also be very demanding on system resources, which may be why you are running into these issues.
We would suggest performing a full virus scan of your computer (Make sure that your anti-virus/anti-malware software and its signatures is fully up-to-date first.)
Please see http://www.virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html for a list of common performance issues and their solutions.
Posted Mon 11 Apr 11 @ 6:22 am
