Topic: [NEW] VirtualDJ 7.0.3 released - Page: 1
Here is a new update for VirtualDJ.
This update mainly adds controllers to the native list.
You can find the changelog in the wiki.
We also used this opportunity to change the installer technology used by VirtualDJ.
On PC, it now uses Windows-compliant .msi installer files.
On Mac, it now uses AppStore-compliant single-files .pkg
But the change in installer technology means that this new version will install new icons (on PC) or application (on Mac).
You can safely delete the old ones from v7.0.2 or before.
As usual, the update is free for licensed users, just get it from your Download Center.
Posted Mon 07 Mar 11 @ 1:27 pm
Nice. So what does the verb "Repeat" do? Tried checking it out on the verbs definitions on the wiki page but its not listed there yet.
Glad to see the bitrate and playlist issues are resolved for mac users. Thanks VDJ Team!
Has this addressed the sound Advanced Config issue whereby you can't use multiple AISO devices?
Not in this release unfortunately. It's not a quick fix as there are different Asio frequencies (44.1 & 48Khz) and they currently won't work together hence the reason that advanced config is still WDM only.
Keith
It allows a button on a MIDI controller to repeat its action when held down, e.g:
repeat 100ms 500ms & browser_scroll +1
repeat 100ms 500ms & effect slider 1 +1
etc.
The Wiki will be updated soon, but context sensitive help is available for new actions in VirtualDJ's CONFIG -> Mappers.
As always, thanks for the update.
-David
DJ Kavika
HELLO
I have a problems with my VMS4
the new version download Virtual dj 7.0.3
The LOOP in, out, beloop, loop does not work on VMS4
Do you have too a problem too ?
In case you use a modified mapper or definition, please make sure that those xml files are still in theire positions (VirtualDJ/Mappers & VirtualDJ/Devices)
Thanks for the 7.0.3 update!
thank you
Dj Dad
it works
I'm so happy
Thanks team for all your hard work and VDJ for the free update! :-)
You might want to quantify that since advanced config is most definitely not WDM only and you can indeed use multiple ASIO devices...
Under native controllers it has the Gemini CDMP-7000. I can't even find any info for this controller on their website, is there any information that you guys can provide us?
do you have to uninstall 7..0.2 and then install 7.0.3?
I'm with Jim, any info on this mystery unit would be wonderful!!
Keep up the great work!
Huey
nice work team!
Quote :
fixed compatibility with 48Khz-only ASIO drivers
does this fix the sound drop-outs on AudioDJ 2 Usb cards??
Will test this later in the day..
SBDJ wrote :
Well it is sad that they don't have it on the website, can't give any info on their facebook page and there is maybe 1 video I have seen of it so far. It is exactly what I am looking for as long as it is built well.
What gives the file msi as opposed to exe ? also what the Difference in mac ? and Thanks for the update !
22%
