I am ready to go live with vdj. I am having problems setup my video mix to be projected on LCD TV as full screen. Right now its on monitor mode. I have tried clicking on detect displays on mac nothing comes up. I have restarted VDJ latest version 6 and it does not detect my video card if I have one LOL?
Someone please help. Do you have instructions on how to set up dual displays for projection on a MAC. I dont want monitor mode.
Thanks.
dj kzelo
http://www.kzelo.com
Model Name: MacBook Pro
Model Identifier: MacBookPro4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.5 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 6 MB
Memory: 2 GB
Bus Speed: 800 MHz
Boot ROM Version: MBP41.00C1.B03
SMC Version (system): 1.27f2
Serial Number (system): W88280V0YJY
Hardware UUID: 5B6F9C34-113B-5783-A2EB-DF195F83237A
Sudden Motion Sensor:
State: Enabled
GeForce 8600M GT:
Chipset Model: GeForce 8600M GT
Type: Display
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 512 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0407
Revision ID: 0x00a1
ROM Revision: 3212
Displays:
Color LCD:
Resolution: 1440 x 900
Depth: 32-Bit Color
Core Image: Hardware Accelerated
Mirror: On
Mirror Status: Hardware Mirror
Online: Yes
Quartz Extreme: Not Supported
Built-In: Yes
LG TV:
Resolution: 1600 x 900 @ 60 Hz
Depth: 32-Bit Color
Main Display: Yes
Mirror: On
Mirror Status: Master Mirror
Online: Yes
Quartz Extreme: Supported
Rotation: Supported
Interlaced: Yes
Television: Yes
Thanks.
dj kzelo
L2 Cache: 6 MB
Memory: 2 GB
Bus Speed: 800 MHz
State: Enabled
GeForce 8600M GT:
Type: Display
Bus: PCIe
Device ID: 0x0407
Revision ID: 0x00a1
ROM Revision: 3212
Displays:
Color LCD:
Depth: 32-Bit Color
Mirror: On
Online: Yes
Built-In: Yes
LG TV:
Depth: 32-Bit Color
Main Display: Yes
Mirror: On
Online: Yes
Rotation: Supported
Interlaced: Yes
Television: Yes
Posted Sun 18 Oct 09 @ 11:47 am
My LG TV is not being detected on virtual dj software through HDMI cable. Thanks.
Posted Sun 18 Oct 09 @ 11:49 am
never mind i figured it out. It was the arrangement of screens that I need to change. Dont use mirror arrangement. Thanks.
Posted Sun 18 Oct 09 @ 1:25 pm
It's great that he figured it out, but I haven't. Can someone help me out??
Posted Sat 07 Aug 10 @ 2:47 am
I don't know if this will help you but it works for me...
You will need a Mini DisplayPort to HDMI adapter and an HDMI cable. Connect it to your LCD and power it on, open VDJ, go to "Config" the video "Video", then click the "TV Output" drop down menu to find your display, select it and then check "Activate"...
For dual LCD displays you will need to purchase an HDMI splitter. I use an LCD and a projector or sometimes I will run two projectors...
Posted Tue 10 Aug 10 @ 3:40 pm
dj rude is da man!!!
Posted Thu 02 Sep 10 @ 9:41 pm
