kradcliffe wrote :
It would be nice as a VDJ and Engine user if I could export from VDJ (with cues, beatgrids etc) to an Engine format then just be able to add new files to avoid maintaining two separate DB systems.
That's what I'm talking about, you don't need to use anything from Rekordbox to use it on the Denon sc6000 for example.
Last night I couldn't use a CDJ3000 due to the error: REKORDBOX DATA NOT FOUND. I thought it was because of the library plus, but CDJ3000 are not compatible with that library. I also used the same USB with a CDJ100 and XDJ the same and it worked. I don't even know what to try.
Posted Sat 01 Mar 25 @ 6:56 pm
Last night I couldn't use a CDJ3000 due to the error: REKORDBOX DATA NOT FOUND. I thought it was because of the library plus, but CDJ3000 are not compatible with that library. I also used the same USB with a CDJ100 and XDJ the same and it worked. I don't even know what to try.You dont need rekordbox, as Denon products read it.
What is the problem??
I do it all the time and it just works.
Otherwise make everything in VDJ and use Lexicon to move it to your Engine software.
Posted Sat 01 Mar 25 @ 6:57 pm
Maybe a bit off-topic but…
I also export to CDJ’s in VDJ and many times when reading the stick in Rekordbox it says ”corrupt database” and it want to rebuild (format) the stick.
So there seem to be some misalignment somewhere..
Posted Sat 01 Mar 25 @ 7:19 pm
é exatamente disso que estou falando desde o inicio!
Posted Fri 23 May 25 @ 6:53 am
HENRY JAY wrote :
That's exactly what I've been talking about all along!
No, you've not mentioned that in any posts in the thread.
Posted Fri 23 May 25 @ 8:27 am
My request is exactly for VDJ to have its own type of export for equipment if possible, and thus avoid these types of incompatibility, when I export to the pendrive to use on the CDJs 3000 it does not work.HENRY JAY wrote :
Posted Thu 24 Jul 25 @ 3:19 am
It already has. Now go and ask AlphaTheta and inMusic to support it on their hardware devices.
Then you're doing something wrong.
I do it all the time and it works every single time.
Not only with CDJ3000, but also with newer devices that use the newer "extended" database format, such as Opus Quad and XDJ-AZ.
Posted Thu 24 Jul 25 @ 5:45 am
