Hi everyone,
I’m using the Gemini SDJ 4000, and I’m having an issue with how it displays files on USB. When I insert a USB stick with folders and subfolders, it reads the files without issues, but some appear in white while others show up in red. I know that using V-Case I can analyze files to get information like waveform, BPM, and other tags, but I’m encountering a few problems:
Color Display: I’d like to understand what determines the color of the files (white or red). Is there a specific tag or setting that affects this display? Ideally, I want all tracks to appear in white.
Organization: V-Case places all analyzed files into a single folder, which makes management difficult. I’m aware I can create playlists, but I can’t organize my tracks by genres and subgenres since sub-playlists aren’t supported. This complicates organizing my library, which is split by genre.
Is there an alternative to V-Case that would allow me to display all tracks in white, or does anyone know how to prevent tracks from appearing in red? All my tracks are MP3 at 320 kbps.
Thanks a lot for any suggestions!
Posted Mon 04 Nov 24 @ 4:00 pm
