Hello everybody,
Can anybody help me further. I use a Numark Mixstream Pro+ as hardware
which I mostly operate as a stand alone device. If I connect it to Virtual DJ (as Pro User) in PC mode, you can see the Numark Mixstream Pro Screen for the Numark under Settings
Download Mixstream, but after the download the Mixstream Pro it is not listed under the skins.
So I have to choose a different surface, you can work with that but it would be much nicer
if I had the same interface of the Mixstream Pro on my PC screen.
Martin
Martin
Posted Tue 23 Apr 24 @ 7:08 am
The Mixstream Pro skin is for the device screen, not your main.
And since it's not designed to be used as a main skin, it is hidden from the Interface list.
I suppose you get the screen skin on the device properly, right ?
Posted Tue 23 Apr 24 @ 8:53 am
